Bullet Hits Block Attached to Spring What am I doing wrong?
The discussion revolves around a physics problem involving a bullet striking a block attached to a spring. The user initially calculates the final velocity of the combined mass after the bullet embeds itself in the block, using conservation of momentum. However, they mistakenly use an incorrect mass for the bullet, leading to an erroneous amplitude calculation for the oscillation. A participant points out the error, noting that the mass of the bullet should be 0.00802 kg instead of 0.0082 kg. Correcting this mistake is essential for accurately determining the amplitude of the resulting oscillation.
sweetpete28
A wooden block of mass M = 1.83 kg is rest on a frictionless, horizontal table attached to the end of an unstretched spring (k = 217 N/m). A bullet of mass m = 8.02 g is fired horizontally into the block at speed vo = 394 m/s. The bullet comes to rest inside the block, and causes the mass to oscillate on the spring. If there is no friction between the block and the table: find A, the amplitude of the resulting oscillation. You can assume the mass never hits the wall (to which the spring is attached.)
Here is what I did, and I really don't see how this is wrong...
By conservation of momentum --> m1v1 = (m1 + m2)v2
(.0082)(394) = (1.83 + .0082)v2
v2 = 1.75759m/s
1/2mv^2 = 1/2kA^2
(1/2)(1.83802)(1.75759)^2 = (1/2)(217)A^2
A = .162m
How is this wrong??
Check the mass value for the bullet that you used in the calculation of v2.
v2 = 1.75759m/s
You dropped a zero from the mass of the bullet.
ehild
