Can Pro-E Conduct Buoyancy Analysis for Underwater Autonomous Vehicles?
  • Thread starter Thread starter only_huce
    Analysis Buoyancy
Pro-E does not include standard buoyancy analysis capabilities, focusing instead on geometry and mass analysis. Users can determine the center of gravity and total displaced volume for basic buoyancy insights. Pro/Mechanica may offer more advanced options, but the process can be time-consuming. The discussion highlights the need for efficient design tools in developing underwater autonomous vehicles. Overall, while Pro-E can assist with some aspects, it lacks dedicated buoyancy analysis features.
only_huce
My robotic team and I are constructing an underwater autonomous vehicle. We are trying to do as much of the design process in Pro-E as possible to make life easier for us down the road. One aspect of testing which would be made much easier is buoyancy testing. Therefore, I was wondering if it possible to do buoyancy analysis in Pro-E. If anyone knows more about this it would be greatly appreciated.
Not in the standard package. You can only do geometry or mass analysis. You will be able to get the overall assembly CG. I don't know about Pro/Mechanica though.
You can do a simple buoancy analysis by doing things like looking at the total displaced volume of the sumersible, the calculated weight, calculating the center of gravity, etc.
I don't use Pro E in my current position but I have worked with other engineers who have used Pro Mechanica and they say it's time to achieve a solution can be very long.
Just thought I would throw that out there.
Thanks
Matt
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
