Calculating Buoyant Force Using Archimedes' Principle
In summary, the conversation discusses an object weighing 5.0 Newtons being dropped into a beaker of water and displacing 3.5 Newtons of water. It also talks about another object with twice the volume but the same weight being dropped into the same beaker and whether it will sink or float. The conversation concludes that the object will float and have a buoyant force of 5 Newtons, as per Archimedes' principle.
Buoyant Force
  • 5.0 N
    Votes: 0 0.0%
  • 3.5 N
    Votes: 0 0.0%
  • 8.5 N
    Votes: 0 0.0%
  • 1.5 N
    Votes: 1 100.0%
  • Other
    Votes: 0 0.0%
  • Total voters
blacklily28
An object weighing 5.0 Newtons displaces a certain volume of water when dropped into a large beaker of water. The weight of the displaced water is 3.5 Newtons. The object is free to sink or float. What would be the value of the bouyant force is another object twice the volume, but having the same weight, was droppen into the large beaker of water? The object is free to sink or float
I believe the bouyant force is 3.5 Newtons, judging from Archimedes' Principle which states that "an object immersed in a fluid experiences a bouyant force equal to the weight of the water displaced." I'm not sure if this is correct, going by volume and not weight.
The first thing to decide is whether it sinks or floats. Well?
Does that one sink or float?
They both sink.
blacklily28 said:
They both sink.
Explain your reasoning.
Because an object will float if the bouyant force (3.5 N) is greater than the weight of the submerged object (5 N) - so in this case the object would sink.
But does the bouyant force change if the volume is doubled?
Good. This means that the entire volume is underwater.
What matters is the volume of the object that is under water.
Hint: If this second object were totally submerged, what would be the buoyant force on it?
3.5 N?
blacklily28 said:
3.5 N?
No. Recall that, per Archimedes' principle, the buoyant force equals the weight of the displaced fluid. The first object was totally submerged, thus it displaced an amount of water equal to 3.5 N. But the second object has twice the volume. So if that second object were totally submerged, it would displace twice the water. How much buoyant force would that equal?
Does the second object float or sink?
It would float- so 5 N?
Right. If the 2nd object were totally submerged it would displace twice the water and thus have twice the buoyant force: 7 N. That's more than enough to support its weight, so it will float only partly submerged. Since you know it floats, its buoyant force must equal its weight = 5 N.
Thanks!
Related to Calculating Buoyant Force Using Archimedes' Principle
1. What is buoyant force and how does it relate to Newton's laws of motion?
Buoyant force is the upward force exerted by a fluid on an object placed in it, which is equal to the weight of the fluid displaced by the object. This force is explained by Newton's third law of motion, which states that for every action, there is an equal and opposite reaction.
2. How does the density of an object affect the buoyant force acting on it?
The density of an object affects the buoyant force acting on it because the amount of fluid displaced by the object is directly proportional to its volume. Objects with higher density will displace more fluid and experience a greater buoyant force, while objects with lower density will displace less fluid and experience a smaller buoyant force.
3. What is the formula for calculating buoyant force?
The formula for calculating buoyant force is FB = ρVg, where ρ is the density of the fluid, V is the volume of the fluid displaced by the object, and g is the acceleration due to gravity.
4. Can an object sink in a fluid without any external force acting on it?
No, an object cannot sink in a fluid without any external force acting on it. According to Newton's first law of motion, an object at rest will remain at rest unless acted upon by an external force. Therefore, an object in a fluid will remain at the same level unless a force, such as buoyant force, acts on it.
5. How does the shape of an object affect the buoyant force acting on it?
The shape of an object does not affect the buoyant force acting on it. As long as the object displaces the same volume of fluid, the buoyant force will remain the same regardless of its shape. However, the shape of an object may affect its ability to float or sink due to factors such as surface area and weight distribution.
