Burt Rutan's newest aircraft design - the SkiGull
  • Thread starter Thread starter aaronhowell
    Aircraft Design
Burt Rutan's latest aircraft design, the SkiGull, features an innovative electric docking system with two motors that allow for maneuverability in tight spaces, enhancing safety during engine failures. The SkiGull's design boasts a lift-to-drag ratio of 23, enabling it to glide back to safety if an engine fails, unlike traditional seaplanes. While sketches of the aircraft exist, they are not being released to maintain confidentiality until test flights. The project is currently seeking funding through a Kickstarter campaign, which has raised half of its $80,000 goal with just a day left. The discussion highlights the excitement surrounding the SkiGull and its potential impact on aviation.
aaronhowell
Burt Rutan is at it again with a new plane the SkiGull -
"Its docking system is two, 5” diameter electric motors each driving a 27” diameter folding prop. These self-contained units (Off-the-shelf motor, controller, batteries used for giant RC models) mount on each wing. They provide forward or reverse thrust to allow backing up or rotating when docking/beaching in winds. Since the SkiGull has an L/D of 23 (it looks more like a motor glider than other seaplanes/floatplanes), its electric docking system can fly it about 8 miles, which greatly reduces the risk of an engine failure, particularly when operating out of small tree-lined lakes. Every other seaplane has to crash straight forward when an engine fails early in the climb, a SkiGull can fly back to downwind & land on the lake into the wind."
NBC did a nice piece on the article - http://www.nbcnews.com/tech/innovat...an-talks-about-skigull-his-next-plane-n321916
Interesting. Are there any sketches or models yet?
There are sketches, but we have been asked not to release them as Burt wishes to keep the plane secret until it's first test flights. I will keep the thread updated.
So you starting this thread is meant to help out the Kickstarter crowdfunding campaign...?
AntennaFilms is sharing details to whet the appetite for the project's Kickstarter crowdfunding campaign. About halfway into the monthlong campaign, the effort has raised about half of its $80,000 goal.
Just thought people might be interest - that campaign ends tomorrow, and I will keep the thread updated into the future, there is a ton of information on the plane, but I just posted what might spark people's interest in learning more - here is a better link perhaps:http://aerosociety.com/News/Insight-Blog/2957/Rutan-film-aims-to-inspire-next-generation
Why do we use inches in a science forum again?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
