Tenshou
- 153
- 1
I am not sure how to assign probabilities to variables do you think you guys will be able to help me?
#include <stdlib.h> // C standard library
float num = rand() % 9; // this is the C rand function, and your number will be between 0-8
if (num < 3)
// do something
else if (num >= 3 && num <= 6)
// do something else
else // implication num > 6 && num <= 8
Adyssa said:I don't use C++, but you can generate a random number and then decide on a course of action depending on the result. For example:
Code:#include <stdlib.h> // C standard library float num = rand() % 9; // this is the C rand function, and your number will be between 0-8 if (num < 3) { // do something } else if (num >= 3 && num <= 6) { // do something else } else // implication num > 6 && num <= 8 { // do something else }
Your random number will be in one of the 3 ranges with 1/3 probability, although it's worth noting that rand() is a pseudo-random number generator, but it's probably fine for your purposes.
What Adyssa wrote is NOT a loop; it's an if...else block. To make this a loop, you would need to embed the if-else block in a loop of some kind.Tenshou said:Thank you! How would you make this loop keep going without terminating?
Tenshou said:so I would make a bool variable and have it always true while the conditional is looping or something of that fashion?
while (true) {
// do something
while (1)
Get a random number (in the range 0 .. RAND_MAX)
Turn it into a probability by dividing by RAND_MAX
if (prob < .3333)
do something
else if (prob < .6666)
do something else
else
do the third thing
