C++ runtime error
  • Thread starter enigma
enigma
Staff Emeritus
Maybe someone can help find what I've done wrong.
I'm using Windows XP, 2.3GHz, 80GB, 256MB, Student Version of MS Visual C++ .NET, 2003 version
I've opened a file up for input, which works fine, but as soon as I try to pull information from the file, it gives exception errors in memory addresses.
If someone can see a blazing error, or knows the fix for this problem, I'd be appreciative.
Relevant code:
Code:
main()
	// Opens file: priorities.dat for
	ifstream inProcesses("priorities.dat", ios::in);
	if (!inProcesses)
		cerr<<"File could not be opened"<<endl;
		exit(1);
	// Ignore first line from file stream
	clearLine( inProcesses );
	// Set up Process pointer array
	Process *dataPtr[30]; // Read up to 30 processes
	int i=-1;
	do
		dataPtr[++i] = new Process();
	}while(inProcesses>>*dataPtr[i]);
void clearLine ( ifstream &input ) // Ignores a line from file stream
	char dump[20];
	input>>dump>>dump>>dump>>dump>>dump>>dump>>dump>>dump>>dump;
        // This is the line where it quits.
// Overloaded input operator from 'Process' object code
istream &operator>>( istream &input, Process &a )
	input>>a.UserID>>a.ProcessID>>a.PPID>>a.CLS
		>>a.Priority>>a.STime>>a.TTY>>a.Time>>a.ProcessName;
        // This is the line which it dumps me if I comment out the first one.
	return input;
This is the file it's trying to read:
Code:
     UID   PID  PPID CLS PRI    STIME TTY   TIME CMD
   johny 27708 27707  TS  48 02:58:05 pts/4 0:00 -tcsh
   mikey 27795 27708  TS  48 02:58:52 pts/4 0:00 pine
  smitty 27846 27846  TS  40 02:59:12 pts/4 0:00 blah1
  ralphy 27915 27916  TS  55 02:59:13 pts/4 0:00 blah2
   carly 27925 27926  TS  12 02:59:13 pts/4 0:00 blah3
Answers and Replies
Hurkyl
Staff Emeritus
Using the extraction operator to read a "char*" is, in general, a bad idea. It just screams, "buffer overflow!" I also notice you don't do any error checking on your stream between reads, another bad idea.
That being said, assuming you've opened the right file, I can't see why it would die on you...
Anyways, the thing you need to investigate is the stream functions "get" and "getline". Generally, you want to use one of these functions to try and grab the contents of an entire line, then use some other means to read the individual tokens, such as string manipulation.
The alternative is to use "string". I don't know how well this works since I tend to avoid using both string and the stream extraction operators (but then again, I've been working on applications where I'm worried about efficiency, so I handle these details myself).
But even if this works, I bet we'll all still be curious what was causing your program to fail. :smile: What I would do in a situation like this is to do the reads one at a time and print them to "cout" to make sure you're getting what you think you're getting.
Jeebus
255
What Hurkyl said, he beat me to this.
dduardo
Staff Emeritus
1,901
Code:
#include <iostream>
#include <string>
#include <fstream>
using namespace std ;
struct process
	string UID ;
	string PID ;
	string PPID ;
	string CLS ;
	string PRI ;
	string STIME ;
	string TTY ;
	string TIME ;
	string CMD ;
istream &operator >> (istream &input , process &p )
	input >> p.UID >> p.PID >> p.PPID >> p.CLS >> p.PRI
	   >> p.STIME >> p.TTY >> p.TIME >> p.CMD ;
	return input ;
void remove_line( istream &input )
	string line ;
	getline( input , line ) ;
int main( void )
	ifstream infile("priorities.dat" , ios::in ) ;
	if( infile.fail() )
		cerr << "File could not be opened" << endl ;
		exit(1) ;
	remove_line( infile ) ;
	process *data[30] ;
	int pcounter = 0 ;
	while( true )
		if( infile.eof() ) break ;
		data[pcounter] = new process ;
		infile >> *data[pcounter] ;
		pcounter += 1 ;
	return 0 ;
Although I am not using your process class, this code is in good working order.
enigma
Staff Emeritus
Meh
It was my own stupid error. I wasn't allocating memory correctly, which was brought about by me trying to do:
char a[] = char b[x],
instead of:
strcpy(a,b)
and changing my variable definitions to pointers to a single memory address to pass the compiler errors for
char a = char b lines.
... been a long time since I've done significantly large programs in C++. Matlab has been spoiling me...:frown:
Suggested for: C++ runtime error
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
