Cable Passing Through Metal: What Is It?
  • Thread starter Thread starter cool dude
    Cable Metal
The cylindrical container near the USB connection on the camera is identified as a ferrite choke, which helps eliminate high-frequency electromagnetic noise from the cable. This choke works by presenting high common-mode impedance to RF signals, effectively acting as a barrier to reduce radiated electromagnetic interference (EMI). While it is common to find these chokes in various devices, their placement is not critical for EMI reduction, as the "break" in the line can be effective at different points. The discussion highlights that while ferrite chokes may not always be necessary, they can improve signal integrity in certain situations. Understanding the function of these components can aid in grasping basic electrical engineering concepts related to noise reduction.
cool dude
Hi,
My camera USB cable has this cylindrical container close to the end where the USB connects to the camera. When I opened it up, the cable was going through two holes in the metal. The metal wasn't perfectly black, and it wasn't smooth.
What is that piece of metal for? I don't know much about electrical engineering.
Thanks.
It's a ferrite choke, to kill high-frequency electromagnetic noise on the line. Arguably, they don't do much under normal circumstances.
- Warren
Thanks. I notice the same thing in other devices as well. Why isn't there one at the end close to the computer?
The choke presents a high common-mode impedance to any RF signals on the cable, so it effectively looks like a break in the line for RF common mode signals. RF common mode signals are what cause radiated electromagnetic interference (EMI), which shows up as noise on broadcast TV receivers and radio receivers. It usually doesn't matter where the "break" is placed in the line for EMI purposes (but not always).
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
