Cable Passing Through Metal: What Is It?
  • Thread starter Thread starter cool dude
    Cable Metal
The cylindrical container near the USB connection on the camera is identified as a ferrite choke, which helps eliminate high-frequency electromagnetic noise from the cable. This choke works by presenting high common-mode impedance to RF signals, effectively acting as a barrier to reduce radiated electromagnetic interference (EMI). While it is common to find these chokes in various devices, their placement is not critical for EMI reduction, as the "break" in the line can be effective at different points. The discussion highlights that while ferrite chokes may not always be necessary, they can improve signal integrity in certain situations. Understanding the function of these components can aid in grasping basic electrical engineering concepts related to noise reduction.
cool dude
Hi,
My camera USB cable has this cylindrical container close to the end where the USB connects to the camera. When I opened it up, the cable was going through two holes in the metal. The metal wasn't perfectly black, and it wasn't smooth.
What is that piece of metal for? I don't know much about electrical engineering.
Thanks.
It's a ferrite choke, to kill high-frequency electromagnetic noise on the line. Arguably, they don't do much under normal circumstances.
- Warren
Thanks. I notice the same thing in other devices as well. Why isn't there one at the end close to the computer?
The choke presents a high common-mode impedance to any RF signals on the cable, so it effectively looks like a break in the line for RF common mode signals. RF common mode signals are what cause radiated electromagnetic interference (EMI), which shows up as noise on broadcast TV receivers and radio receivers. It usually doesn't matter where the "break" is placed in the line for EMI purposes (but not always).
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
