Calc derivatives - Minimum total surface area in a box of V = 160 ft2
Dave_1420
Hi everyone! I'm new to online math forums. I wonder if anyone can give me a hand on this - it would be greatly appreciated.
Thank you in advance!
Dave
If a box with a square base and an open top is to have a volume of 160 cubic feet, find the dimensions of the box having the minimum total surface area. Use calculus to find the solution.
If X are the sides of the base, and Y is the height of the box, what would be the formula to find surface? How can the minimum surface be calculated using derivative applications?
Surface = minimum possible
In terms of x and y, formulate an expression for the total outer surface area of the box.
If "x" is the length of a side of the square base, y is the height of the box, then the base is an "x by x" square and there are four sides that are "x by y" rectangles. Do you know how to find the area of squares and rectangles?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
