How Does a Small Change in Speed and Angle Affect Projectile Range?
reddawg
The range of a projectile fired (in a vacuum) with initial velocity V0 and inclination angle θ from the horizontal is R = (1/32) * (V0)2 * sin(2θ).
Use differentials to approximate the change in range if V0 is increased from 400 ft/s to 410 ft/s and θ is increased from 30° to 31°.
Setting up my equation:
dR = (∂R/∂V0) * dV0 + (∂R/∂θ) * dθ
Taking the partials and substituting values:
sin(60°)/250 + cos(60°)/10,000 = 5216.51 ft.
This answer seems unreasonable, can anyone check my work?
It's not clear what you have done since you don't show all the steps in taking your differentials.
Did you apply all of the derivative rules correctly? I can't tell from the attempt at your solution, since you have already substituted numbers. What happened to the factor (1/32) from the original range equation?
The attempt at a solution:
Taking the partials:
∂R/∂V0 = (sin(2θ)*V0)/16
∂R/∂θ = (cos(2θ)*(V0)2)/16
dV0 = 10
dθ = 1
I then substituting and simplified.
Did you use radian measure for your dθ?
I thought I had calculator in degree mode, however I went back through with radian and verified d(theta) was in radians.
Also there was a sign error in my calculations so the new answer is 129.24 ft which seems more reasonable don't you think?
Yes.
Likes 1 person
