CalcBC-6 Derivative Question (1989)
  • Thread starter Thread starter Loppyfoot
    Derivative
Loppyfoot
http://img96.imageshack.us/img96/1278/70542563.th.jpg
http://img96.imageshack.us/img96/1278/70542563.jpg
The problem statement is as follows:
If h=0, show that f(-x)=1/f(x)
So here is what I have gotten. f(x+0) = (f(x) + f(0)) / f(-x) + f(-0)
What does f(-0) equal? Is it 0, or 1?
Because if f(-x)=0, then after some simplifying, I get f(-x)=(f(x)+1) / f(x)
Thanks
Can you folks see the image?
I didn't see it at first, but it says:
Let f be a function that is everywhere differentiable and that has the following properties:
(i) f(x + h) = \frac{f(x) + f(h)}{f(-x) + f(-h)} for all real numbers h and x
(ii) f(x) > 0 for all real numbers x
(iii) f'(0) = -1
I must admit I don't see the answer right away. Anyway I can tell you that f(-x) is not zero, because of property (iii). In fact you shouldn't assume a value for f(x) at all, because that would mean that f is a constant function.
Probably you should use that it is differentiable:
f'(0) = \lim_{h \to 0} \frac{f(h) - f(0)}{h}
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
