Calculate Angle & Speed of Rock Launched from Cliff Catapult
  • Thread starter Thread starter booneyromper
    Catapult
A catapult launches a rock from a height of 34.0 meters at an unknown speed towards a ship, with the projectile in flight for 6.00 seconds and covering 174 meters horizontally. The horizontal velocity was calculated to be 29 m/s, while the vertical velocity was found to be 23.73 m/s. Using these values, the launch angle was determined to be approximately 39.29 degrees. The total launch speed of the rock was calculated to be 37.47 m/s. Proper nourishment is emphasized as beneficial for solving complex physics problems.
booneyromper
A catapult on a cliff launches a large round rock towards a ship on the ocean below. The rock leaves the catapult from a height H of 34.0m above sea level, directed at an angle above the horizontal with an unknown speed. The projectile remains in flight for 6.00 seconds and travels a horizontal distance of 174m. Assuming that air friction can be neglected, calculate the value of the angle (in degrees). Also calculate the speed at which the rock is launched.
My brains are cooked. I'm not sure where to begin with this one.
Cooked brains or not, please show your reasoning and lots of working. :smile:
What are the equations governing the motion of a projectile ?
Thanks for the hint. I took a break, ate dinner, shook off the frustration, then came back and solved the problem
For horizontal velocity X = Xo + (Vxo)t,
174m = 0+(Vxo)6.00s,
Vxo = 29 m/s
For vertical velocity Y = Yo + (Vyo)T - 1/2gt^2,
-34m = (Vyo)6.00s - (1/2)(9.8m/s^2)(6.00s^2)
Vyo = 23.73m/s
So the angle theta = tan-1 (23.73/29) = 39.29deg
and the rock is launched at... Square root of (29^2 + 23.73^2) = 37.47
The moral of the story is don't do physics on an empty stomach.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
