Calculate between [-epsilon,epsilon]
  • Thread starter Thread starter alejandrito29
The discussion revolves around integrating the equation -(p(y)f(y)')' = m^2w(y)f(y) with specific functions defined for p(y) and w(y). The user is uncertain whether to calculate the integral between [0, epsilon] or [-epsilon, epsilon], especially given that f is not continuous at zero. A participant clarifies that if the integral is definite, the provided limits should be used, while noting that continuity is crucial for differentiability at zero. The result derived is f(+epsilon) = -\frac{m^24akf(0)}{1-4ak^2}, but the correctness of this result is questioned due to a lack of clarity in the problem statement. The conversation highlights the importance of defining the problem accurately before proceeding with integration.
alejandrito29
i need to integrate
-(p(y)f(y)')'=m^2w(y)f(y)
where
p(y)=e^{4ky}(1-4ak^2) and w=-4ae^{2y}k\delta(y)
but y between [0,infinity[
¿i calculate between \int^{epsilon}_0? or ¿i calculate between [-epsilon,epsilon]?
but, what is??
\int^{\epsilon}_0(p(y)f(y)')'dy
whit f is not continuous in zero
the result is
f(+\epsilon)=-\frac{m^24akf(0)}{1-4ak^2}
Mathematics news on Phys.org
alejandrito29 said:
i need to integrate
where
I have no idea what you are talking about. What are yu integrating? If you are talking about the integral above, if it is given as a definite integral, you use whatever limits of integration are given. If it is given as an indefinite integral (anti-derivative) you do not use any limits of integration.
but, what is??
By the Fundamental Theorem of Calculus, the integral of the derivative of any function is that function:
\int^{\epsilon}_0(p(y)f(y)')'dy= p(y)f(y)'
If f is not continuous at zero, then it is not differentiable at zero and the integrand above does not exist at 0.
the result is
Since you haven't actually stated what the problem is, I have no idea whether that is correct or not.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 31 ·
  • · Replies 22 ·
