Calculate charge on a body(in Coulombs)
  • Thread starter Thread starter HurricaneJesus
    Charge Coulombs
The discussion revolves around calculating the final charge on a body after adding electrons to it. Initially, the user calculated the charge as 1.337 uC but later realized the need to account for the negative charge of the body, leading to a correction. After confirming the calculations, the final charge was determined to be -1.337 uC. Participants emphasized the importance of checking negative signs in such calculations. The user expressed gratitude for the assistance and indicated a commitment to using the forum for future homework help.
HurricaneJesus
All right i have a simple problem but i just want to verify my results, so any help would be greatly appreciated. The problem is as follows:
7.1* 10^12 electrons are added to a body that already has a negative charge of 0.2uC(the u is micro 10^-6). Calculate the final charge on this body.
Now i have
(7.1* 10^12)(1.602* 10^-19) + (0.2* 10^-6)
which gave me 1.337 uC
is this correct?
whoops, i think it should have been:
(7.1* 10^12)(- 1.602* 10^-19) + (0.2* 10^-6)
which gave me 0.937 uC
now I am lost...please help.
new info, 1C is equal to 6.24* 10^18 electrons
ok, formula should be:
(7.1* 10^12)/(6.24* 10^18) + (0.2*10^-6)
= 1.337 uC which is the same as the first result i got... 0_o
i am going to go with this one.
is this correct?
Check all of your negative signs. The problem states that the body already has a negative charge,
Your magnitude looks right, but the sign is wrong.
[mod hat]
Moving the thread to homework help.
[/mod hat]
Thanks you were right about the sign, it was supposed to be -1.337 uC
Also, sorry about the location of my topic i only put it there because the course i am taking is electrical engineering and there was a section that matched exactly. I just joined the forum and i already know i will be here every day to read up on the info i need. Thanks again for the help, i will keep all homework related problems here.
