Calculate concentration of an acid
  • Thread starter Thread starter Physicsrapper
    Acid Concentration
To calculate the concentration of sulfuric acid (H2SO4) using a neutralization equation with NaOH or KOH, one must know the formula weights of H2SO4 and the chosen base, as well as the molarity of the base and the amount of the H2SO4 sample. The balanced neutralization reaction is H2SO4 + 2NaOH → Na2SO4 + 2H2O, indicating a 1:2 molar ratio between H2SO4 and NaOH. The calculation involves determining the moles of the base used in the titration, which can then be used to find the moles of H2SO4 present in the sample. Additional details about the sample's form, concentration, and volume are crucial for accurate calculations, as these factors influence the methodology and final concentration results. For comprehensive guidance, consulting a general chemistry textbook on neutralization titrations is recommended.
Physicsrapper
How can I calculate the concentration of sulfuric acid with help of a neutralisation equation? (in mol/l or g/l)
Neutralisation takes place with either NaOH or KOH.
I've been searching for a tutorial for hours, but didn't find anything helpful.
Could someone please explain me how to do it? I would appreciate it a lot!
Chemistry news on Phys.org
ANY, ANY GOOD analytical or general chemistry textbook will have instruction for this. Even an "elementary chemistry" textbook may have good information about neutralization titrations.You must know the :
Formula weight of H2SO4
Formula weight of either the KOH or the NaOH
Molarity of the KOH or the NaOH
Amount of sample containing the H2SO4
You may need to refer to the balanced written reaction for any help on ratios, if any needed.
H2SO4 + 2NaOH --------> Na2SO4 + 2H2O
What help do you need from here? How is your sample form? Liquid containing sulfuric acid? High concentration expected? Expecting volume taken and diluted? Expecting MASS taken and diluted? Expecting sample MASS or VOLUME but undiluted? If diluting, what size aloquot?
This would become a lot easier if you could elaborate on the parameters you do have with you (volume of H2so4, molarity of base, etc). Once you mention that the relevant equation can be obtained.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
