Calculate DC current through an inductor?
In a series DC circuit with a 100V source, a 1.5H inductor, and a 1nF capacitor, the current after closing the switch for 2 microseconds can be calculated using the differential equation for the circuit. Initially, the user attempted to apply V=L*di/dt but realized the capacitor's charge affects the current. The correct approach involves solving a second-order differential equation that accounts for both the inductor and capacitor, leading to a damped/driven harmonic oscillator response. The discussion highlights the importance of understanding the impulse response of RCL circuits and the role of the Heaviside step function in the analysis. Mastery of these concepts is essential for accurate calculations in transient responses.
hobbs125
Hi everyone,
Say I have a series DC circuit. The circuit contains a 100V DC source, a switch, a 1.5H inductor, and a 1nF capacitor (all in series).
If I close the switch for 2uS what is the current at that time?
Initially I thought I could rearrange V=L*di/dt to
V*Ton/L = di/dt which would be 100*.000002/.150=1.3mA?
For some reason I am thinking this is not right since the capacitor charge should also effect the current.
Can anyone help me understand and calculate this correctly?
Once you have turned the circuit on it settles to a steady state very quickly - so you use V=IR - where R is the DC resistance of the inductor. An ideal inductor is just a length of wire ... R=0.
The transient response requires you solve the differential equation.
For an ideal switch closed for time T, ##v(t)=V_0\big ( u(t)-u(t-T)\big )##
Include the cap voltage too, which is 1/c times integral of i(t) dt. Basically a KVL. Take derivative to get rid of integral and get a 2nd order diff eq. Then solve for i(t)
Ok, I guess I need to go study differential equations. Never got that far in math.
Could anyone show me step by step how to solve?
I missed the cap - right ... the solution is a damped/driven harmonic oscilator.
You can look it up. The driving function is the unput voltage as a function of time.
The u(t) function in post #2 are the Heaviside step function ... which you can look up too.
It would be a bit like pushing a pendulum off equilibrium and holding it for a bit before letting it go.
What you get is, basically, called the "impulse response" of the RCL circuit.
That's something else you can look up.
If you set it up right you can make it "ring" like a bell.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
