Calculate Falling Pot Velocity: Lw, t, g
  • Thread starter Thread starter reesejm
    Falling Velocity
To calculate the height from which the flower pot was dropped, use the visible time t and the vertical length of the window Lw, with gravity g as the acceleration. The final velocity can be determined from the time the pot is visible, and since it was dropped (initial velocity is zero), the motion can be analyzed using the equation v_f² = v_i² + 2ad. By substituting the known values into this equation, the distance above the window can be calculated. The discussion concludes with a successful resolution of the problem.
reesejm
This is a question in my homework asignment, and i am completely lost. Please help. Thanks
As you look out of your dorm window, a flower pot suddenly falls past. The pot is visible for a time t, and the vertical length of your window is Lw. Take down to be the positive direction, so that downward velocities are positive and the acceleration due to gravity is the positive quantity .
Assume that the flower pot was dropped by someone on the floor above you (rather than thrown downward).
From what height h above the bottom of your window was the flower pot dropped?
Express your answer in terms of Lw,t , and g.
From the height of your window and the time it was visible, you can get the velocity, and from there you can get the distance above from the equation v_f^{2} = v_i^{2} + 2ad
You know the final velocity from the height of your window and time, you know the initial velocity was 0 unless it was thrown up or down (outward makes no difference since we are considering only motion in the vertical direction), you know the acceleration is gravity, and you know the distance is the height of your window. Can you plug all that in and solve for d?
I was able to figure it out, thanks
