Calculate Rocket Launch Speed | Andrew's Problem
The discussion revolves around calculating rocket launch speed based on thrust and mass. Andrew initially miscalculates acceleration by using thrust in kilograms instead of converting it to Newtons, leading to confusion. The correct acceleration is derived from the thrust converted to force (12,250N), resulting in approximately 35 m/s². For final velocity, the acceleration can be multiplied by time, but real rockets require accounting for changing mass due to fuel consumption, necessitating the use of the rocket propulsion equation. Understanding the symbols in the equation and the concept of exhaust velocity is crucial for accurate calculations.
PhysicsAdict
Hey Guys,
I have a problem,
Say I have a rocket that has a mass about 350kg and produces 1250kg of thrust and I launch it horizontally, I know that 1250/350 gives me the acceleration in m/s2 (roughly 3.6 m/s2) but how do I then work out the speed?
Also if I where to launch the rocket vertically would I need a different equation to incorporate the force of gravity and if so how would I do that?
Thanks for your help!
Andrew
the expression of the rocket propulsion is that
Vf - Vi = Ve ln(\frac{Mi}{Mf} )
I hope it helps
yea Ve is the escape velocity
I hope it helps
Thanks for the help but you seem to know quite a lot more about this than I do, could you please tell me what each symbol in that equation represents please.
Thanks again for your help!
Andrew
This is incorrect.
Why should it be 3.6m/s² and not, say ft/s²? Or miles/hr²? Or any other unit of acceleration?
If you take 1250kg/350kg = 3.6. There are no units. You get a unitless quantity for something that should have a unit. That should be your first warning sign.
You cannot have 1250kg of thrust. Thrust is a force, and kg are units of mass. Two entirely different quantities. What you really have is the amount of thrust equivalent to weight of 1250kg under normal Earth gravity. That's 1250kg * 9.8m/s² = 12,250N of thrust.
Now the acceleration is F/m = 12,250N/350kg = 35m/s². That's your acceleration. Note that this is roughly 3.6G, which is really what you get when you divided the two numbers above.
If the thrust and the mass of the rocket remain constant, then the final velocity is just acceleration * time. So if your rocket was running for 5s, the final velocity would be 35m/s² * 5s = 175m/s. Notice that the units still work out.
However, a real rocket produces thrust by burning fuel, so its mass will decrease. That's why you generally need to use the equation given by the_storm. In that equation,
Mi = Initial mass of the rocket.
Mf = Final mass of the rocket.
ve = Exhaust velocity. Also known as Specific Impulse.
vi-vf = Change in velocity you get between Mi and Mf states of the rocket.
ln(x) = Natural logarithm.
The problem, of course, is finding ve for your rocket. It's not always given. However, most rocket engines give total impulse. For a rocket with constant thrust, total impulse can be found by multiplying thrust by amount of time the engine runs. Then, if you take that total impulse and divide it by (Mi-Mf) you will get exactly ve. Note that if total impulse is given, this will work even if total thrust is not constant, because thrust usually varies due to the rate at which the fuel is burnt, and not due to the changes in ve.
If you are just curious, I hope that clears a few things. If you have a more specific problem in mind, you'd probably have to share some more details before we can help you better.
all of what you said is correct :).
physicsadict listen to K^2.
Best regards
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
