Calculate the components of the vector
  • Thread starter Thread starter MoreZitiPlease
    Components Vector
To calculate the components of a vector with a velocity of 40 m/s at a 55-degree angle, the correct approach is to use the angle directly rather than subtracting it from 180 degrees. Using 55 degrees allows for accurate calculation of the x and y components, which are found using cosine and sine functions. The confusion arose from referencing a different scenario that involved a second quadrant vector, leading to incorrect component values. The proper method involves drawing a right triangle with the angle of 55 degrees to visualize the components clearly. Understanding the physical context is crucial for applying trigonometric principles correctly.
MoreZitiPlease
Calculate the components of the vector representing a velocity of 40m/s and an 55 degree angle.
none
180-55=125
40(sin125)=33
40(cos125)=-23
(-23,33)m/sec
correct?
Why did you take 180-55?
you could have just used the 55 degree angle...but it is still correct...
not really..
40cos125=-23
40cos55=23
two diffferent answers
...you would get the same resultant...but the vectors are the same, just in opposite directions
I suppose it depends on what orientation you use, but generally I would have thought that cos(55) would be what was being asked for.
MoreZitiPlease said:
not really..
40cos125=-23
40cos55=23
The answers would be definitely coming different. As you are using two different vectors. Why are you doing 180 - 55.Its just 55. And doing so you will get its x and y components.
When you take 180 - 55 then you are taking a vector which is in the second quadrant which is different from the vector in the first quadrant.And we want to find the component of the vector which is in the first quadrant.
so I should use 55? In my textbook it showed 180-55, that's why I used 125. But that example involved a car route or something.
Yes, you should use 55.
This is a prime example of focusing too much on equations and trying to follow previous methods without actually thinking physically about what you are trying to do.
Draw a right angled triangle, with the bottom angle of 55 degrees, and the length of the hypotenuse as 40. Now, the x and y components are the horizontal and vertical sides of the triangle, respectively. You should be able to use trigonometry on this triangle in order to find the components.
ok, thx
