Calculate the force on a circular surface
4 replies · 5K views
jonjacson
Hi to everybody
(The attachment has an image with this problem)
A small probe P is gently forced against the circular surface with a vertical force F as shown. Determine the n- and t-components of this force as functions of the horizontal position s.
Newton laws and basic trigonometric relationships.
Well I show in the attachment my reasoning, the force F is applied at the contact point C, I have represented the direction in which this force acts (vertical line). I need to find the proyections of F to the n and t axis, to calculate Fn and Ft in red.
Well I think that the angle between the vertical line and the line connecting the center O and the point C is the same angle between F and Fn, in the picture they are called A. I simply write:
Fn= F cos(A)
Ft= F sen(A)
And I can calculate A as:
A=arcsen(s/r)
But I have seen the answers provided in the book and they are:
Ft=Fs/r
and
Fn= -(F√(r2-s2))/r
Does anybody know what is Fs?
And I have no idea where the equation for Fn comes from.
Why are my answers so different to the ones in the book?
Thank you
"Fs" is F*s, not Fs. Looks like they are avoiding using sin, cos in the answer.
jonjacson said:
Fn= F cos(A)
Ft= F sen(A)
A=arcsen(s/r)
Looks good. (The sine function is generally written sin rather than sen.) From A=arcsin(s/r) you get sin(A) = s/r. Try substituting this expression for sin(A) into your expression Ft= F sin(A) and compare to answer in book.
How would you write cos(A) in terms of s and r?
Yes you are right, thank you very much.
The sinus is simply s/r and I get the Ft.
For the Fn it´s the same, they avoid to use the cos, to calculate the other leg of the triangle I use the pythagorean theorem r2=s2+y2 where I called y the other leg of the triangle. So the cosinus is exactly the answer in the book.
Thank you very much to both of you, I have more doubts with problems in this book, hope to see you in the other threads.:biggrin:
