Calculate the force on the other support
A uniform thin rod weighing 100 N is supported by two bricks, each initially bearing 50 N. When one brick is removed, the force on the remaining support needs to be calculated. The discussion highlights confusion regarding the necessary equations, particularly in relation to torque and the role of length in calculations. It emphasizes that while length is typically important for torque problems, it may not be needed for this specific calculation. The key takeaway is to apply standard equations for linear and angular acceleration to determine the force on the remaining support.
H_Ab
A uniform thin rod of weight 100 N is supported horizontally by two bricks at its
ends. At t=0 one of these bricks is kicked out quickly. Calculate the force on the
other support immediately thereafter.
I'm not sure if I am on the right track with this equation since I don't have the length and from what I know, I need the length for torque problems: Mg(L/2)sin(theta)
I thought since each brick has a force of 50N that if one brick is locked the force on the supporting brick is -50N since it's a downward force. Please help me with the equation and how to go about it. Thanks
Follow that through and see what happens. Maybe the length will not feature in the answer.
(From dimensional analysis, you can predict that it won't. Given an acceleration (g) a mass and a length as input, and a force to be the result of multiplying and dividing these and raising them to powers, the only combination that works is acceleration * mass * constant.)
So what would my constant be? My weight would be 50N since it's for one brick, and my acceleration is 9.81m/s. I'm confused about the constant.
You need to determine that by working through the usual equations.
Create unknowns for mass, length, angular acceleration and write out the standard equations for linear acceleration versus force and angular acceleration versus torque.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
