Calculate the force that each wire exerts on each other
  • Thread starter Thread starter tasha_michelle
    Force Wire
Two parallel conductors with a length of 0.05m and opposite currents are analyzed, with one carrying 10A. The distance from point C to the other wire is determined to be 2D/3, where D is 24cm. The magnetic field at point A, located at the midpoint of the first wire, can be calculated using the superposition principle. The formula for magnetic field strength due to a current in a wire is essential for finding the resultant field at A and the current I in the second wire. The discussion emphasizes using these principles to calculate the forces exerted between the wires.
tasha_michelle
need help asap...by 2:30 :(
if 2 parallel conductors with the same length of .05m have their currents going in opposite directions, one conductor carries a current of 10A. C=D/3, D=24cm, I is adjusted so the magnetic field @ C=0.
a. find the value of the current I
b. value of magnetic field @ point A (find magnitude & direction)
c. calculate the force that each wire exerts on each other
What is the formula for the magnetic field strength as a function of current and geometry.
I take it that C = D/3 is measured from the wire with the 10 A current? Then the distance from C to the other wire is 2D/3.
Does this look familiar - http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcur.html
Umm - where is A? One can use superposition of fields.
A is at the midpoint of the first wire...
A
I <---------------------
--------------------->10A
C
a is at the midpoint of the first wire, C is at the midpoint of the second wire...what is the equation?
OK - but write the equation for the magnetic field due to a current in a wire, and determine the field due to 10A at D/3. The using that field and 2D/3, solve for the current in the other wire.
Then knowing the currents, solve for the resultant field at A.
See this - http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/wirfor.html
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
