Calculate the quantum number of an electron given its velocity
To calculate the quantum number of an electron in a one-dimensional box, the kinetic energy (KE) must be compared with the energy levels defined by the equation En = n²(π²ħ²)/(2ml²). The electron's speed of v=10⁻⁴c and the box length of 48.5 nm lead to a calculated KE that initially appears too low, prompting a reevaluation of the approach. By utilizing the rest energy of the electron and incorporating factors of c, the kinetic energy can be expressed in eV, simplifying the calculations. Ultimately, the quantum number n can be determined by equating the kinetic energy with the energy level equation.
MatrixMan87
An electron moves with speed v=10-4c inside a one dimensional box (V=0) of length 48.5 nm. The potential is infinite elsewhere. The particle may not escape the box. What approximate quantum number does the electron have?
En = n2\frac{\pi^{2}\hbar^{2}}{2ml^{2}}
KE = \frac{mv^{2}}{2}
9.1e-31 kg / electron
6.2e18 eV / J
I know that I need to find the kinetic energy of the electron and compare it with the various energies given by the first equation above in order to determine the value of n. However, I keep getting values for E that are far too small:
KE = \frac{mv^{2}}{2} = \frac{1.9\times10^{-31} kg \times (3\times10^{4} m/s)^{2}}{2} \times 6.2\times10^{18} eV/J = 5.301\times10^{-4} eV
This is far lower than the energies I get out of the first equation above, so I think that I'm missing something up to this point.
I get a different value for the kinetic energy (~2.5 meV).
What did you get as ground state energy?
6.2e18 eV / J
You can make your life quite a bit easier if you learn to throw in convenient factors of c and get used to working with eV instead of joules. For example,
$$K = \frac{1}{2}mv^2 = \frac{1}{2}(mc^2)\left(\frac{v}{c}\right)^2,$$ where the rest energy of the electron in eV is ##mc^2=511000\text{ eV}##. You can now easily see what the kinetic energy should be without a calculator.
The combination ##\hbar c = 197\text{ ev nm}## is a useful one to memorize as well. Again throwing in a few factors of c, we find that the n-th energy level is given by
$$E_n = \frac{n^2\pi^2\hbar^2}{2ml^2} = \frac{n^2\pi^2(\hbar c)^2}{2(mc^2)l^2}.$$ You should be able to see the units work out quite easily if your express ##l## in nm, yielding an answer in eV.
Thanks Vela, that's exactly what I needed.
I was able to equate the kinetic energy equation with the orbital energy level equation and solve for n, like so:
http://imgur.com/7a7uu
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
