Calculate the rate of energy output of the sun, taking the sun as a blackbody
The discussion focuses on calculating the sun's energy output using its surface temperature of approximately 5800K and radius of 6.96x10^8m, applying the blackbody radiation formula H = εσAT^4. A participant initially misinterprets the question, calculating energy per unit area instead of total power output. The correct approach involves using the total surface area of the sun to determine the overall energy output in watts. Clarifications highlight the importance of distinguishing between radius and Stefan-Boltzmann constant in the calculations. Accurate calculations are essential for understanding the sun's total energy output.
ninaw21
1. The surface temperature of the sun is approximately 5800K. Given that the radius of the sun is 6.96x108m calculate the rate of energy output of the sun, taking the sun as a blackbody.
2. H = εσAT4
3. Surface temp = 5800K, Radius of the sun = 6.96x108, Emissivity of a blackbody = 1
H = εσAT4
H/A = (1)(6.96x108)(5800)4
= 7.87x1023W/M2
Am I right??
No. Question is asking for "the rate of energy output" which is power (watts). You also seem to be confusing radius with σ, Stephan's constant.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
