Calculate the resolution of pressure sensor ( altimeter ) ?
The resolution of a pressure sensor, particularly in altimeters, is determined by the sensitivity of the device rather than solely the barometric equation. The discussion emphasizes that different pressure sensors exhibit varying levels of sensitivity and resolution, which are intrinsic characteristics of the devices. For accurate altitude measurements, one must also consider the reference barometric pressure at a known altitude, denoted as ##P_0##. This is commonly obtained from local airport readings, which are used to calibrate onboard equipment in aircraft.
  • Understanding of the barometric equation
  • Knowledge of pressure sensor types and their characteristics
  • Familiarity with sensitivity and resolution concepts in sensor technology
  • Basic principles of altitude measurement using pressure
  • Research the characteristics of different pressure sensors, focusing on sensitivity and resolution
  • Study the barometric equation in detail and its application in altitude calculations
  • Learn how to obtain and utilize local barometric pressure readings for calibration
  • Explore advanced pressure sensor technologies and their applications in aviation
This discussion is beneficial for engineers, aerospace professionals, and students studying sensor technology and its applications in altitude measurement.
ThienPhuNg
How can I calculate the resolution of a pressure sensor used to measure height ( altimeter ) ? We have barometirc equation ( refer to http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/barfor.html#c3 ) , and I can't find out the solution.
Can the resolution be the same as the sensitivity which infered by diriving the barometric equation ?
Barometric equation
I can't attempt an solution because of being stuck in many problems =.=
You can't get the sensitivity of a pressure sensor from the equation you will use the pressure in. You need to know something about the device you will use.
Just to emphasize, here is an extreme example. Some pressure sensors consist of a diaphragm that pushes a "dimple" in or out. If the pressure rises above some set point, the dimple pops in. It stays there until reset. The sensitivity of such a device is "the pressure went above X" and that's it.
Other pressure sensors are much more sensitive and have much better resolution. This will be a characteristic of the device.
That sensitivity will then allow you to infer a sensitivity to altitude using the equation you refer to. Plus you need to know some estimate of the barometric pressure at some reference altitude. That gives you the ##P_0## in your equation. For example, planes frequently get barometric pressure readings for local airports. They then use this to update the reading on their on-board equipment.
