Calculate the rotational inertia through integration
The discussion centers on understanding the relationship between mass and radius in calculating rotational inertia, specifically why the moment of inertia is expressed as I = mr^2. It is explained that I = mr^2 derives from the definition of moment of inertia for a point mass rotating around an axis. The conservation of angular momentum and the relationship between angular velocity and radius are also highlighted, emphasizing that as radial distance decreases, angular velocity increases to maintain conservation. The analogy between angular momentum and kinetic energy is presented to clarify the definition of moment of inertia. Overall, the conversation aims to deepen the understanding of rotational dynamics through mathematical relationships.
jamie.j1989
hello, I've gone through countless textbooks and website trying to find the deeper relation between the mass and the radius when calculating the rotational inertia of an object, however know one is giving it up. I know how to calculate the rotational inertia through integration, and i know how to use the equation, but why does I=mr^2.
I = mr^2 is the moment of inertia of a point mass rotating around an axis. It follows almost directly from the definition of the moment of inertia.
In circumnavigating motion the following quantity is a conserved quantity: \omega r^2
(The greek letter \omega stands for the angular velocity)
That is: if the centripetal force that sustains the circumnavigating motion has reduced the radial distance by half then the angular velocity has doubled.
Angular momentum is defined as m \omega r^2
Angular momentum is defined that way to capitalize on the conserved quantity \omega r^2
In the absence of a force linear momentum is conserved; in the absence of a torque angular momentum is conserved.
So your question translates to: in circumnavigating motion, why is the quantity \omega r^2 conserved?
To some extent that question is answered by the https://www.physicsforums.com/showpost.php?p=2701193&postcount=1" in a recent physicsforums thread.
As radou has said it's the definition of moment of inertia. In principle you can't question the definition. Definition is like axiom in Maths.
But perhaps you would better digest it if you see an analogy. Continuing to talk on lines similar to Cleonis, we can go reverse from your understanding of angular momentum ( I hope you find the definition of angular momentum more palatable).
L=r X mv
But v=rw. Therefore L=mr^2w.
Thus you may justify Moment of Inertia (I like to call it angular mass) to be equal to mr^2.
If you are equally confused about why angular momentum is defined so, try going back from kinetic energy of body moving in a circle. It is (1/2)mv^2=(1/2)mr^2w^2=(1/2)Iw^2.
By analogy, the current definition of moment of inertia has the same relationships with angular velocity, as those between normal mass and linear velocity.
Regards,
-sgsawant
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
