Calculate the velocity of the projectile
Fadi A.Saif
A stone was thrown with initial velocity of 100 m/s. Calculate the velocity of the projectile at 10 m of height. (Consider g=10m/s^2, and neglect the effect of air molecules)
where's the error in the following sollution?
Vr= sqrt((Vx)^2+(Vy)^2)...(1) (Resultant velocity).
Vx= Vi cos(a)...(2)
Vy=Vi sin(a)+(-2gy)...(3)
sub. (2)& (3) in (1)
Vr = sqrt(Vi^2 (cos(a))^2+Vi^2 (sin(a))^2+(-2gy)); taking Vi as a common factor, and sqrt of both sides; we get
Vr = sqrt(Vi^2-2gy) then we proceed by applying the given data from the problem
The error is right here
Vy=Vi sin(a)+(-2gy)
This equation is not dimensionally correct.
Thanks Kuruman... so I believe it should be like this
Vy^2= Vi^2 (sin(a))^2 - 2gy.
That's more like it.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
