Calculate the width of the gutter where the depth is 6cms
  • Thread starter Thread starter Paulo2014
    Depth Width
To calculate the width of the gutter where the depth is 6 cm, the quadratic equation y = (4/11)x^2 - 4x + 11 must be solved for x when y equals 6. The equation becomes (4/11)x^2 - 4x + 11 = 6. After simplifying, it is necessary to rearrange the equation to find the roots, which represent the width. The initial guess of 1.26 cm is questioned, indicating a need for clarification on the correct method to solve the quadratic. The discussion emphasizes the importance of correctly identifying the variables in the equation.
Paulo2014
The cross-section of a gutter can be represented by the quadratic:
y=4/11x^2-4x+11 where x and y are measurements in cm. Calculate the width of the gutter where the depth is 6cms.
my answer was 1.26cm or 12.6mm but I'm pretty sure that's wrong so could someone please explain how to work it out?
What did you try?
It's impossible to say if you won't tells us which of x, y is the width and which is the depth! I might guess that x is twice the width and y the depth, so that you need to solve the equation (4/11)x^2- 4x+ 11= 6. My guess is partly based on the fact that if x is the depth, you would only need to evaluate that (4/11)(6)^2- 4(6)+ 11 and that is too easy!
sorry guys... x is width and y is depth
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
