Calculate velocity at a certain time in an acceleration.
The discussion centers on calculating the speed of a car at 250 meters during its acceleration from 36 km/h to 80 km/h over a distance of 500 meters. The initial calculations involve converting speeds to meters per second and determining average speed and time, but the user struggles with the application of formulas. Key points include the misconception that the car is at the halfway point at half the time and the suggestion to use suvat symbols for clarity. Ultimately, the calculated speed at 250 meters is approximately 47 km/h. The conversation emphasizes the importance of correctly applying physics principles in kinematics.
Viktor Haugland
A car accelerates from 36 km/h to 80 km/h o range of 500m.
What's the speed at 250m?
Answer with two value figures and the unit "km/h".
Am I using the wrong formulas or something?
What am I missing?
36 km/h = 10 m/s
80 km/h = 22,22 m/s
avg. speed = 0,5(22,22 m/s + 10 m/s) = 16,11 m/s
time = 500 m / 16,11 m/s = 31,03 s
acceleration = (22,22 m/s - 10 m/s) / 31.03 = 0,39 m/sSo I'm thinking like this (but it's wrong for some reason):
10 m/s + 0.5 * 0,39 m/s * (31,03 s / 2) = 13,05 m/s
13,05 * 3600 / 1000 = 46.98 km/h
Answer: 47 km/h
Any thoughts?
Two thoughts:
1) What makes you think the car is at the halfway point at half the time?
2) What you have is a lot of numbers and it's very difficult to see what you're doing or to spot a mistake. It should be a lot easier if you work with ##suvat## symbols.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
