Calculating/3D Modeling Salt Water Current Paths
To calculate or 3D model the path of current in a saltwater medium between two electrodes, one must consider the electric potential and current density, which are influenced by the geometry of the container and electrodes. Analytic solutions to this problem can vary in complexity based on boundary conditions. Measuring techniques, such as using a probe and voltmeter, can provide practical insights into current paths. This approach is also applicable in fields like aerodynamics and electrostatics for designing insulators. Understanding these factors is crucial for accurate modeling of current flow in saltwater.
A.J.710
Just to clarify, this is not a homework or coursework question.
I was wondering, if you have a large container of salt water and place two electrodes on either side, the current will pass from one electrode to the other through the salt water medium. Is the a way to calulate or 3D model the path of the current as I assume it occupies a certain volume between the two electrodes?
You have to solve for the electric potential and streamlines (current density) through the medium. This is a standard problem in electrostatics, although analytic solutions may or may not be easily found depending on the geometry and boundary conditions. If by volume you mean the total amount of salt water present, then no, that is not enough to solve the problem. The geometry of container and electrodes is important.
In principle, it can also be measured using a probe and a voltmeter. This technique is used for modelling aerofoils, and also for electrostatic problems such as the design of insulators.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
