Calculating Benzoic Acid Moles & Percent Purity
The discussion focuses on calculating the moles of benzoic acid (C6H5COOH) and determining the percent purity of a sample. A sample weighing 0.9734 g was titrated with 31.78 mL of 0.09251 M NaOH solution. To find the moles of benzoic acid, the equation n1v1=n2v2 is utilized, where normality equals molarity. The purity is assessed by comparing the calculated weight of benzoic acid to the original sample weight, with a formula to determine percent purity if the sample is not pure.
  • Understanding of titration and equivalence point concepts
  • Knowledge of molarity and normality in solutions
  • Familiarity with stoichiometry and mole calculations
  • Basic chemistry knowledge regarding molecular weights of elements
  • Learn how to perform titration calculations using the formula n1v1=n2v2
  • Study the concept of percent purity in chemical analysis
  • Explore the molecular weight calculations for organic compounds
  • Investigate the properties and reactions of monoprotic acids
Chemistry students, laboratory technicians, and anyone involved in analytical chemistry or titration experiments will benefit from this discussion.
feelau
chem question please help
Ok, so there's .9734 g sample which contained monoprotic benzoic acid C6H5COOH and it's dissolved in 75 mL of water and titrated to the equivalence point with 31.78 mL of .09251 M NaOH solution. a) how many moles of benzoic acid were titrated b) Was this a pure sample of benzoic acid? c) If the sample is no, Calculate its percent purity.
The attempt at a solution
ok so for the first problem part a is pretty easy but then I have no idea how to determine if this sample is pure and how to calculate percent of purity.
In this case, for both the acid and base, normality equals molarity. Hence you can use n1v1=n2v2.
You know for sure the 31.78ml of .09251M soln were used. You are unsure of the weight of benzoic acid. Hence, N*75=31.78*.09251. From this you can calculate N. This much in any case you've figured out... right?
Now, molarity=normality, therefore you know the number of moles. You have the formula for benzoic acid so you know the weight of benzoic acid. You know the number of moles, so you can find the weight of the sample of benzoic acid titrated. If that weight equals .9743 grams, then the sample is 100% pure, else (weight/.9734)*100 is your percentage.
If you don't know the weight of 1 mol of carbon/oxygen/hydrogen:
C=12gms
0=16gms
H=1gm
Thank you so much. I've never seen any problems with this question so I had no clue. Thanks!
