Calculating change in velocity with resistance
The discussion revolves around modeling the change in velocity of a particle subjected to a constant force and resistance proportional to the square of its velocity. Participants explore the mathematical formulation of the problem, particularly in the context of varying initial velocities and the effects of changing force directions.
  • One participant presents the equation of motion as m.dv/dt = f - kv², seeking to find the velocity at time t given an initial velocity v0.
  • Another participant outlines two cases based on the relationship between initial velocity v0 and terminal velocity vt, providing formulas for each scenario.
  • Distance traveled is expressed in terms of initial conditions and hyperbolic functions, with a specific formula introduced for both cases of initial velocity.
  • A participant raises concerns about the behavior of the model when the force direction changes, noting that existing formulas do not yield a velocity less than the initial velocity when the force opposes the motion.
  • Further clarification is provided on how to handle negative forces, suggesting a switch to a different formula once the velocity reaches zero.
  • Another participant attempts to define velocity for cases where the initial speed is greater than terminal speed and the force is negative, but encounters issues with the resulting equations.
  • A participant shares a code snippet illustrating how the formulas are implemented in a programming context, discussing the handling of acceleration and deceleration in small time intervals.
Participants express differing views on the applicability of the formulas under various conditions, particularly regarding the effects of changing force directions and the behavior of the system when transitioning from positive to negative velocities. The discussion remains unresolved as participants explore these complexities without reaching a consensus.
Participants note limitations in the existing formulas when applied to scenarios involving negative forces and changing directions, highlighting the need for careful consideration of initial conditions and the physical interpretation of the results.
kennethgilpin
Hi everyone,
I'm a doctor who is fair at maths - haven't done physics for a while. I'm trying to model some heart physiology which I can describe as a mechanics problem:
I have a particle, mass m, with a constant force acting on it, f.
It also has resistance R, where the resistance is equal to the velocity of the particle squared times a constant k:
R = kv2
my equation of motion is:
m.dv/dt = F = f - kv2
I want to find the velocity after a given time. The are formula on the internet which describe a solution to this problem (mostly in the context of a falling body accelerating to wind resistance):
http://keisan.casio.com/has10/SpecE...sistance (velocity and distance)/default.xml"
However they all assume that starting velocity is zero. I need a solution for any starting velocity. so:
t0 = time 0.
v0 = velocity at time 0.
f = constant force on particle
m = mass
R = resistance = kv2 as above, where k = constant, v = velocity
what would be the velocity at time t?
I know this is difficult. I'm not sure if this is really a maths problem.
kenneth
In short, you have two cases: either the speed will start below the terminal speed and increase or it will start above terminal speed and slow down. The terminal speed is where the acceleration is zero,
(1) v_t = \sqrt{f/k}
so for v_0 < v_t the solution for v is
(2) v = v_t \tanh(\frac{k v_t}{m} t + \textrm{arctanh}( \frac{v_0}{v_t} ) )
where \tanh and \textrm{arctanh} are hyperbolic tangent and its inverse, and for v_0 > v_t it is
(3) v = v_t \coth(\frac{k v_t}{m} t + \textrm{arccoth}( \frac{v_0}{v_t} ) )
where \coth and \textrm{arccoth} are hyperbolic cotangent and its inverse.
By the way, the distance traveled will in both cases end up being expressed by
(4) s= s_0 + \frac{m}{k}\log\left[\frac{v_0}{v_t}\sinh(\lambda t)+\cosh(\lambda t)\right]
where I've introduced the constant
(5) \lambda = \frac{k v_t}{m} = \frac{\sqrt{fk}}{m}.
thank you for your quick reply. The function seems to work well in with a few test examples I've just put in.
the problem is for my use is with deceleration due to a change in direction of the force, f.
if I have a positive velocity, v0, but a negative force, f, then function (2) does not provide a v less than then velocity v0.
clearly if the terminal speed is related to the root of the force then it cannot be negative. If I use the absolute force and multiple the terminal speed by the direction of the force, i.e.
vt = |f|/f * \sqrt{}|f|/k
then the terminal speed has the same sign as the force direction, which makes sense. However, when this number is put into function (2) the subsequent value, v is still greater than v0.
any ideas?
k.
Ok, I assumed f was positive. If f is negative, you would normally write the differential equation as
(6) m\dot{v} = -f - k v^2
with f positive. This equation has the solution
(7) v = v_t \tan(\arctan(v_0/v_t)-\lambda t)
for initial speed v_0 and the time in the range 0 \le t \le t_1, where
(8) t_1 = \arctan(v_0/v_t)/\lambda
is the time until the particle has reached zero speed. After that time the movement of the particle is governed by (2) with initial speed zero. The position for (7) in the same time range is
(9) s = s_0 + \frac{m}{k}\log\left[\frac{v_0}{v_t}\sin(\lambda t)+cos(\lambda t)\right]
thank you all of the formula work wonderfully.
You haven't defined v in the case of f being negative, and also v0 > vt. I assumed it might be:
<br /> v = v_t \cot(\cot^{-1}(v_0/v_t)-\lambda t) <br />
(can't find the Latex for arccot!)
but this doesn't work out, and when I graph the solution the gradient is positive (i.e. the solution, v, is larger than v0). Could you help me out for the last time?
increasingly gratefully,
kenneth
I didn't explain it properly. For a negative force (i.e. here a force that oppose the initial direction of speed), you can use (7) no matter what the initial speed is. However, (7) can only be used until the speed reaches zero (which it does after the time shown in (8)) since for negative speeds the fixed minus in front of the drag force will make drag force act in same direction as the speed, which is not physical.
So, when the speed reach zero using (7), you will have to switch to using (2) (which handles the case where speed and force point in same direction for low initial speeds) with initial speed zero and you will now have to consider the speed calculated from (2) as being in the opposite direction as it was when using (7).
For example, let's say your particle moves so that positive speed is to the right and with the force pointing left. You use (7) until v = 0 and then use (2) with v0 = 0 and where you now consider positive speeds pointing left (and the force still pointing left). If you are interested in the distance traveled too you will also have to carry over the distance from (9) as initial distance in (4) when switching equations and, like with the speed, consider the distance to now increase in the other direction.
I hope its a bit more clear now otherwise just ask.
Filip thank you a thousand times for your help with this problem.
I just wanted to tie this thread off in case someone else comes here looking for a solution. You can see that I've used some of the formula above but haven't written in the need to decelerate (or accelerate) the particle to zero when changing direction. I think this is because I'm using these formulae in a loop in a computer program which considers small intervals of time. Filip Larson might want to comment on the code. This snippet is in an ECMA script language:
Code:
var dt:Number = 0.005; //seconds per interval, so 200 intervals = 1sec
var i:int=0;
var f:Number = 10;  //force
var v:Number = 0;   //velocity - starting from stationary here
var k:Number = 0.1; //constant
var m:Number = 5;   //mass
//determine terminal velocity
var Vterm:Number = Math.pow(Math.abs(f/k),0.5);
//introduced constant
var gam:Number = Math.pow(Math.abs(f * k),0.5) / m;
for (i; i < 600; i++)	{
//i.e. 600 / 0.005 = 3 secs
//is velocity above terminal speed?
if (Math.abs(v) < Math.abs(Vterm))	{
   if (dP > 0)	{	//accelerating
	v= Vterm * advMath.tanh(gam * dt + advMath.atanh(v/Vterm));
   else	{	//decelerating
	v= Vterm * Math.tan(Math.atan(v/Vterm) - gam * dt);
else	{  //is velocity below terminal speed
	v= Vterm * advMath.coth(gam * dt + advMath.acoth(v/Vterm));
	var newVel:Number = Vterm * advMath.cot(advMath.acot(v/Vterm) - gam * dt);
	v +=  v - newVel;
        //this is clearly a fudge
where advMath.coth etc. are custom functions for the hyperbolic cotangents etc. See wikipedia for the formulae.
hope this helps someone. I'm a big fan of this forum
kenneth
Code:
var i:int=0;
	v +=  v - newVel;
Some quick comments:
  • If you want to tabulate the speed of a particle, you should probably calculate each speed value from the original solution using total time. In the code above, the analytical solutions are used to advance the speed from the speed at time t to the speed at time t+dt and then this speed is used as the initial speed for the next time step. Doing that will make the solution "drift" due to truncation and rounding error in the calculations. A numerically more stable technique is to calulate t = t0+i*dt and v = vsolution(t), using the appropriate solution depending on conditions.
  • The particle can be in four different regimes based on its initial speed and direction relative to the force. Classifying the regimes based on what type of function used for the speed solution we have that regime 1 corresponds to the tan solution, regime 2 to the tanh solution, regime 3 to the terminal speed solution, and regime 4 to the coth solution. A particle in regime 2, 3 and 4 will always stay the same regime, while a particle in regime 1 will eventually migrate to regime 2.
  • It is probably easier to keep the force always positive and use the sign of the speed to indicate if it is opposite the force or not, for instance using negative speed when the particle is moving opposite the force.
If I modify your code to incorporate the above points, I get the following UNTESTED code:
Code:
// parameters
var f:Number = 10;  //force - always positive
var v0:Number = 0;  //initial speed  - positive when same direction as f
var k:Number = 0.1; //constant - always positive
var m:Number = 5;   //mass - always positive
var t0:Number = 0;  // initial time
// state variables
var v:Number = v0;  //speed - positive when same direction as f
var t:Number = 0;   // time
var i:int=0;        // step number
var vt:Number = Math.pow(f/k, 0.5);
var gam:Number = Math.pow(f*k, 0.5) / m;
//time parameter used in the four regimes
var tz:Number = t0;
if (v0 < 0) {   // regime 1 - speed opposing force
  tz = Math.atan(-v0/vt)/gam;
} else if (v0 < vt) { // regime 2 - speed non-negative and below vt
  tz = advMath.atanh(v0/vt)/gam;
} else if (v0 == vt) { // regime 3 - speed equal vt
  // nothing special
} else { // regime 4 - speed above vt
  tz = advMath.acoth(v0/vt)/gam;
for (i; i < 600; i++) { //i.e. 600 / 0.005 = 3 secs
  t = t0 + i*dt;
    if (t < tz) { // still in regime 1?
      v = -vt * Math.tan(gam * (tz-t));
    } else { // swith to regime 2 solution
      v0 = 0; t0 = tz; tz = 0;
      t = t0 + i*dt;
  if (v0 >= 0) {
      v = vt * advMath.tanh(gam * (t+tz));
      v = vt;
      v = vt * advMath.coth(gam * (t+tz));
  // print or use t and v here
thank you for your reply. I've been using a mixture of your code and mine and it's been working well. I think that there is another regime and i wanted your opinion/help for it:
where, speed is above vt _and_ speed opposes the force.
once again you would still need a 'tz' time parameter for when/if the speed changes direction.
kenneth
There should be no need for more regimes. The tan solution (regime 1) is valid for all speeds in opposite direction of the force. The terminal velocity does not have direct physical meaning as a terminal velocity in this regime since the terminal is relevant only for regime 2, 3 and 4. The time parameter tz in regime 1 signifies the time it takes for the particle to change speed from -v0 to 0 and is theoretically valid for arbitrarily negative speeds.
I now notice that the code I included in #9 is wrong regarding switching from regime 1 to 2. It should be
Code:
    } else { // switch to regime 2 solution
      v0 = 0; tz = -tz;
With this change t0 is always zero and could be left out.
