Calculating Coil Windings in Generators
  • Thread starter Thread starter amintanharpd
    Formula Generators
To calculate coil windings in generators, Faraday's law is essential, expressed as ξ = -N (dΦ/dt), where N is the number of loops and Φ represents magnetic flux. Magnetic flux is defined by the equation Φ = BA cos φ, linking the magnetic field strength, the area through which it passes, and the angle of incidence. Understanding these principles helps determine the average EMF induced in the coil. The discussion also emphasizes the importance of knowing the generator's design specifics for accurate calculations. Additional resources were shared for further reading on the topic.
amintanharpd
hi , i want to know that how calculate coil windings in the genarators,
i want make a small genarator with magnetic and copper coil for 12 volt but i couldn't find a formula for number of coil cycle please guide me about this , thank u.
The equation you're looking for is known as Faraday's law.
\xi =-N \frac{d \Phi}{dt}
What this says is that the average EMF induced in a coil of N loops depends upon the rate of change in magnetic flux through one loop.
\Phi = BA \cos \phi is a general expression for magnetic flux that says magnetic flux is equal to the magnitude of the magnetic field, times the area of the surface the flux is passing through, times the cosine of the angle that the flux makes with the normal to the surface. i.e if the flux is perpendicular to the surface, \cos 0 = 1 so it disappears from the equation.
Do you have any further information regarding how you are going to make this generator?
You can do further reading here;
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c1
thank u very much , the link and your information about that was very useful for me thank u ;)
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
