Calculating cost to heat house using R-values
  • Thread starter Thread starter nerdy_hottie
    Heat
The discussion focuses on calculating the monthly heating cost for a flat-roofed house using R-values for insulation. The house dimensions and R-values for walls and roof materials are provided, along with indoor and outdoor temperature averages. The heating power (P) is calculated using the formula P=(1/R)*A/ΔT, leading to a total heat loss of 2,803,968 Btu over 30 days. The final cost is derived by converting Btu to gallons of oil and multiplying by the cost per gallon, resulting in a monthly heating expense of approximately $112.16. A correction is noted regarding the inclusion of both walls in the calculations.
nerdy_hottie
Consider a flat roofed rectangular house that is 10.0 feet high with 39.0 feet long sidewalls and 20.0 feet long front and back walls.
We are given that:
Wall: (R Value =0.20 plaster)+(R Value=10.00 insulation)+(R Value=0.60 plywood)+(R Value=0.50 cedar shingles).
Roof: Same as walls except R Value=31.00 insulation.
All R values are in units of ft2*oF*hr/Btu
If average winter indoor and outdoor temperatures are 69.0oF and 18.0oF respectively and the furnace produces 105 Btu/gal of oil at $4/gal, what is the monthly heating cost in dollars? (Use 30 days/month and Do not enter units)
P=(1/R)*A*/\T
P=(1/Rfront wall, back wall)/\T*(Afront wall+Aback wall)+(1/Rroof)*/\T*Aroof
=3894.4 Btu/hr
multiply by 24 hours, then by 30 days=2803968 Btu
Divide by 10^5 Btu/gal
multiply by $4/gal
=112.16
nerdy_hottie said:
=3894.4 Btu/hr
I think you've counted only one wall in each direction instead of a pair.
