Calculating current through solenoid?
  • Thread starter Thread starter scoopaloop
    Current Solenoid
To calculate the current in a solenoid using a bar magnet, Faraday's law is applicable, specifically the equation E=N(dphi/dt). Moving the bar magnet towards the solenoid induces a voltage, which can be measured with a voltmeter or multimeter, indicating a change in magnetic flux. The magnetic field of the bar magnet can be expressed as B=(μ₀/4π)(2m/r³), where m is the magnetic dipole moment and r is the distance from the midpoint. The dipole moment m is calculated as m=n(2L)I(πa²), with L being the length from the midpoint to one end and a the radius. Understanding these relationships allows for the determination of current in the solenoid based on the induced voltage.
scoopaloop
Not for a class or anything, just out of curiosity, how would you calculate the current in a solenoid, not given a magnetic field, but just using a bar magnet? I know it will just be some form of Faraday's law. E=N(dphi/dt). Maybe not. I'm imagining all I'm really missing is how to calculate the magnetic field of the magnet. Thanks.
Take the solenoid and connect a voltmeter or multimeter across it. Move the barmagnet towards the solenoid and there should be a deflection in the voltmeter because ##\phi## changes when you keep moving the barmagnet.
or as you know, the bar magnet is also like a solenoid. The expression for magneticfield for barmagnet along axis is $$B=\frac{\mu_0}{4\pi}\frac{2m}{r^3}$$
So, just a little clarification, I did a little research online, is M the magnetic strength of each pole and r, I take it is the distance?
Thanks btw.
M is the magnetic fipole moment. Here, ##m=n(2L)I(\pi a^2)##
L is the length from midpoint to one end and 'a' is the radius. 'r' is the distance from midpoint to any point along the axis.
Awesome. Thank you
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
