MHB Calculating Data Set w/ MEAN=100 & STD DEV=15 & n=3
It is possible to reverse calculate a data set with a known mean of 100 and standard deviation of 15 for n=3, but it requires setting up a system of equations due to the underdetermined nature of the problem. Users can generate random numbers using Excel's NORMINV(RAND(), 100, 15), but this may not yield a dataset that meets the specified mean and standard deviation. To achieve the desired values, one can generate n-2 random numbers and then calculate the remaining values to satisfy the equations for mean and standard deviation. The final solution involves solving a quadratic equation derived from the conditions set by the mean and standard deviation. Understanding this process allows for the creation of a valid dataset that meets the specified statistical criteria.
fieldmusic123
If I know the mean and standard deviation, but I don't have an original data set, is it possible to reverse calculate a data set that has this known mean and std dev? Is there an excel function I could use to do this easily? I know there could be multiple correct datasets and that's fine, I'm just wondering if it's possible to reverse derive a correct one that has the known mean and std dev.
So, for a MEAN = 100 and STD. DEV= 15, can anyone tell me how to calculate a data set with n=3?
Many thanks.
Mathematics news on Phys.org
I've wondered this same problem myself. The problem is much more difficult with larger data sets (you would just have to assume certain values), although with a large enough data set, you can just go with a normal distribution, and generate a whole raft of values from a known normal distribution. That procedure might not be exact, but it would be close. The larger the data set the closer it would be.
For $n=3$, you can set up a system of equations:
\begin{align*}
100&=\frac{x_1+x_2+x_3}{3} \\
15^2&=\frac12\left[(x_1-100)^2+(x_2-100)^2+(x_3-100)^2\right]
\end{align*}
Since you have three unknowns and two equations, this is an underdetermined system. Just pick one value, and the other two will be determined.
Many thanks.
Hi fieldmusic123! Welcome to MHB! (Smile)
It's [m]=NORMINV(RAND(), mean, stdev)[/m].
To explain, the CDF of some x has the range 0 to 1.
When we generate a random number between 0 and 1 from the uniform distribution, we can use the inverse CDF to find the corresponding random x value.
Hey there, thanks for the welcome and your reply! NORMINV(RAND(), 100, 15) in Excel will give me 3 random numbers in what looks like a normal distribution but the 3 numbers as a combined data set do not give a mean of 100 and std dev of 15. Is there perhaps a way to use Excel to manipulate one of these values so that the set has the required mean (eg. 100) and std dev (eg. 15)? I'm a little rusty with complicated maths. Cheers, Sean
As Ackbach explained, you can generate $n-2$ numbers this way, say $x_3...x_n$, and calculate $x_1$ and $x_2$ to match from:
$$\begin{cases}\mu &= \frac{x_1+x_2 + \sum x_i}{n} &= 100 \\
\sigma^2 &= \frac{(x_1-100)^2 + (x_2-100)^2 + \sum (x_i-100)^2}{n} &= 15^2\end{cases} \\ \Rightarrow
\begin{cases}x_2 &= 100n - \sum x_i - x_1 &= A - x_1 \\
(x_1-100)^2 + (x_2-100)^2 &= 15^2n - \sum (x_i-100)^2 &= B\end{cases} \\
\Rightarrow\begin{cases}x_2 = A - x_1 \\
(x_1-100)^2 + (A - x_1-100)^2 = B\end{cases}
The last equation is a quadratic equation that can be solved with the quadratic formula yielding $x_1$, after which the first equation gives $x_2$.
Dear Ackbach and I Like Serena, thanks very much for your help, now I understand. All the best.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
