Calculating DC Motor Parameters for a Pick and Place Robot
  • Thread starter Thread starter jyothi1
    Dc Motors
To calculate the parameters for DC motors in a pick and place robot, start by determining the weight to be moved, the desired speed, and the length of the lever arm. These factors will help in calculating torque requirements and selecting appropriate motor specifications. Understanding the robot's degrees of freedom is also crucial for effective motor control. Additional details about the specific application and constraints will aid in providing more tailored advice. Accurate calculations are essential for optimal motor performance in robotic applications.
jyothi1
Hi sir,
I am new about to this site.Actually I am an embedded engineer.
Right now I am working on :smile:Pick and place robot.I want to control dc motors.
I don't have any datasheet of DC motor.But I want to know how to calculate dc motors parameters required for the moments of robot.Right now I am using 5 degrees of freedom of robot.Can anyone please tell me what are the parameters and how to calculate those parameters.Please send me as early as possible.:smile:
You start with how much weight you need to move how fast on what length of lever and work backward... Can you specify your requirements a bit more?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
