Calculating Energy Usage of a Hair Dryer
  • Thread starter Thread starter aquamarine08
    Energy Hair
The discussion focuses on calculating the energy usage of a 1650-W hair dryer over specified time periods. For part (a), the correct calculation of energy in joules is achieved using the formula w=Pt, resulting in 9.9 x 105 J when converting 10 minutes to seconds. In part (b), the total energy usage over 4.5 hours is calculated to determine the cost on an electrical bill at a rate of 12 cents/kWh. The correct approach involves converting hours to minutes and then to seconds for accurate calculations.
  • Understanding of electrical power calculations (P=IV)
  • Knowledge of unit conversions (minutes to seconds)
  • Familiarity with energy cost calculations (cents/kWh)
  • Basic algebra for solving equations
  • Learn about unit conversions in physics, specifically time and energy
  • Study the relationship between watts, joules, and time
  • Explore how to calculate energy costs based on usage
  • Review the principles of electrical power and energy efficiency
Students learning about electrical power, physics enthusiasts, and anyone interested in understanding energy consumption and cost calculations for household appliances.
aquamarine08
[SOLVED] Power problem!
(a) How many joules of electrical energy are used by a 1650-W hair dryer in 10 min? (b) If the dryer is operated a total of 4.5 h during one month, how much will this contribute to the electrical bill if the billing rate is 12 cents/kWh?
P=[tex]\frac{w}{t}[/tex] --> w=Pt
(a) w=Pt -> (1650)(10)= 16500 J
I figured since the answer was supposed to be in Joules, I would use the equation w=Pt to figure out the amount but I ended up getting the wrong answer. The correct answer is 9.9 x [tex]10^{5}[/tex].
(b) Since I didn't get the right answer for (a) I knew my answer wouldn't be right here either. I don't really know how to solve this question either but I figured I should convert the 4.5 h into minutes so it matches the amount for part (a)..so I got 190 minutes, and that's pretty much it.
Please help, we didn't get any notes to refer to for this homework and it is our first day learning about Power. :confused:
Thanks so much.:smile:
For part (a): since 1 Watt = 1 Joule/second, you need to change the 10 minutes into seconds to keep your units consistent.
ok thanks...i got part a! now I am just workin on b...
  • · Replies 60 ·
  • · Replies 22 ·
