Calculating Final Momentum in Inelastic Space Rock Collision
The discussion revolves around a problem involving the calculation of final momentum in an inelastic collision between two rocks in space. The first rock has a specified mass and initial velocity, while the second rock is initially at rest. The problem requires determining the final momentum of the second rock after the collision.
  • Participants explore the conservation of momentum principle, with one attempting to relate the final momentum of rock 2 to the initial momentum of rock 1. Questions arise regarding the assumptions about the masses of the rocks and the nature of the collision.
There is an ongoing exploration of the conservation of momentum, with participants questioning the validity of certain assumptions and suggesting that momentum should be considered in each dimension. Some participants have provided guidance on how to approach the problem, but no consensus has been reached regarding the final calculations.
Participants note the lack of information regarding the mass of rock 2 and the implications of assuming an elastic versus inelastic collision, which affects the calculations of kinetic energy and thermal energy conversion.
lebprince
In outer space rock 1, with mass 6 kg and velocity < 4100, -2900, 3200 > m/s, struck rock 2, which was at rest. After the collision, rock 1's velocity is < 3900, -2400, 3700 > m/s. What is the final momentum of rock 2 (p2f)?
ok from my understanding of head on collision of non equal masses (honestly the problem deosnt tell me if they are equal masses or not so i assumed they are not. so i got p2f = 2p1i
that is the final momentum of rock 2 is equal to twice the initial momentum of rock 1.
so initial momentum of rock one = 6 * < 4100, -2900, 3200 > = <24600,-17400,19200> so the final momentum of rock 2 would be 2*<24600,-17400,19200> =<49200,-34800,38400>, but its telling me wrong answer. anything am doing wrong. Thanks.
Remember momentum is conserved.
ok so the change of momentun in the system + the change of momentum in the surroundings = 0 here we are ignoring the surrounding so pf system - pisystem = 0 ?
Hello Lebprince,
How did you manage to achieve this result (i.e. p2f = 2p1i)? Wouldn't it be more accurate if you consider consider the conservation of momentum in each dimension separately, since it is (or, at least the question is) presented as a head-on collision?
Regards,
Horatio
horatio89 said:
Hello Lebprince,
Regards,
Horatio
ok so would this make sense now? p1f + p2f = p1i + p2i ?
so 6<3900,-2400,3700> + p2f = 6<4100,-2900,3200> + <0,0,0> and then i can find p2f?
If we assume the collision is head-on, your solution would and should be right.
Regards,
Horatio
Regards,
Horatio
Thanks i got that part right. can i get some help on this?
Suppose the collision was elastic (that is, no change in kinetic energy and therefore no change in thermal or other internal energy of the rocks). In that case, after the collision, what is the kinetic energy of rock 2?
i wanted to use K= p^2/2m i have p but i don't have m. so any other way around it? Thanks
You know the magnitude of the velocity change in rock1 and you know it's mass
If no energy is lost all this ke must have all gone into rock 2. You would need the mass of rock2 to get it's speed but not it's ke.
ok thanks i used Efsystem = Eisystem and figured it out. Thanks but when thermal energy gets involved it confuses me like this question suppose that in the collision some of the kinetic energy is converted into thermal energy of the two rocks, where Ethermal,1 + Ethermal,2 = 1.44106 J. What is the final kinetic energy of rock 2? i just don't get what to do here
If it isn't elastic, ie. if kinetic energy is lost, than you need more information so solve it.
so if we have an inelastic collision what would i need to calculate DeltaEthermalA + DeltaEthermalB? Thanks
  • · Replies 47 ·
  • · Replies 22 ·
18K
