Calculating Heat Loss in a Home Heating System
3 replies · 11K views
marmulak
Hi every body
This question came to my mind when I was looking at a Home Heating System.
The system is a closed loop. In this closed loop of pipe hot water is flowing.
I know the temperature of the pipe in the beginning and at the end of the pipe.
I also know the flow rate of water in the pipe.
I want to calculate the heat loss in this circulating system.
For example at the beginning of the pipe I have the temperature of 50 centigrade degree, and at the end of the pipe this temperature becomes 40 degrees, if the water flows at the rate of 8 ft/m, then how much is the heat loss in this system.
I am an electronics engineer and I don't know how to calculate this.
Thanks for your help.
This takes me back to the Callender and Barnes experiment we did in the V1 form. If you know the temperature change and the rate of mass flow then that will tell you the Power being delivered to the house.
Power (in Watts) = Temperature Change X Specific Heat of Water X kg of water flow per second
Nots: it's not the speed of the water that counts - it's how many kg per second are going through. You will need to get out a bucket and a stopwatch! Actually, if you know the speed and the diameter of the pipe, you could work out the volume per second - which gives the mass etc. etc. Is the speed you refer to the speed of water in the main output of the boiler?
You can substitute imperial units and still get the answer. (SI rules in UK and most of Science and you would need an answer in kW, in the end. no?)
Your answer lies in the formula for Btu. 1 degree F x 1Lb of water= 1 btu.
T1-T2 x flow in Lbs/ hr will yield Btuh.
The tough part is 1) accurate flow measurement and 2) accurate temp measurement.
Remember to convert Gpm to Gph by multiplying by 8.33 ( Lbs/ gallons)
Sorry for the imperical units, its how I learned it and I'm too old to change.
All that remains is to count the cost in Pounds Shillings and Pence.
Can you really be that much older than I?
I did the Imperial thing at School - 32 ft/sec/sec and all that but it was more than 50 years ago.
