Calculating Heat Loss via Radiation Transfer
To calculate heat loss from a body through radiation, the surrounding temperature should reflect local conditions, influenced by factors like clear skies or cloud cover. The emissivity of materials varies with wavelength, complicating assumptions about uniform emissivity, especially for substances like snow. When estimating sky temperature, a rough approximation can be to assume it as 0K, but this may introduce errors if emissivity is not accurately accounted for. The discussion highlights discrepancies in calculated heat flux from solar radiation versus heat loss, suggesting that steel may have lower emissivity in infrared than expected. Accurate modeling of heat flow often relies on experimental data rather than purely theoretical calculations.
chetanladha
Hi.
I want to calculate the heat which will be lost from a body at temperature 't' to the atmosphere through radiation heat transfer. I can use Stephen's Boltzmann equation, but what should i take the temperature of surroundings as?
Should it be the temperature of air or space?
Thanks.
Science news on Phys.org
It depends on weather conditions and surroundings.
Have you ever parked your car wintertime (clear night) on the open area or under tree or under open sched? It gets more frosted on the open area, as it loses heat to the sky, while under sched you should take the temperatur of sched roof.
Similar effect you may find comparing temperature on clear and cloudy nights - clear nights are much colder, because you lose heat to the sky, why on cloudy nights most of the radiation is reflected.
BTW - using Stefan's law - be careful - most of the objects cannot be treated as black-body. Even if some object is visually black, don't believe it is also 'black' outside visual spectrum.
That was a good description.
I am giving the value of emmissivity in Stefan's law, so i guess that shouldn't be a problem.
I am calculating the radiation heat loss from a steel plate in open atmosphere clear sky. So, now what should i take the temperature of sky as?
Not be that sure. For most substances emissivity depends on a wavelength. So you should rather integrate Planck's law over wavelength, than assuming it is uniform. For many materials results may dramatically differ. Snow is a perfect example - having very small emissivity in visual spectrum, while pretty large in infrared - that's why the weather changes to much colder as soon as first snow covers ground.
As the rough approximation you may just forget about sky temp and assume it is 0K. Error you make will be still much less probably than by assuming uniform emissivity of of your plate.
Thanks a lot. It was really helpful.
Hey.. Sorry but 1 more small q.
I calculated the heat flux from sun on my plate to be around 51kW. (assuming solar intensity 1000kW/m2).
The stephen law gives me heat lost to the surroundings in order of 72kW (using constant value of emissivity).
Apart of not using constant value of emissivity, can i assume part of heat is going to air at 30 C and rest to 0 K.
Also m really afraid of integrating Plank's law, unless its a must..
What do u think..??
Oh, I see you must live in some place in the world where my examples with car getting frosted in the night and snow emissivity are not so common experience :redface:
Probably your steel has lower emissivity in infrared than in visual spectrum. Your result is against my intuition: it absorbs less from Sun than emits. It would mean it is getting colder than surroundings. My intuition tells me that steel (maybe except very shiny polished acidproof steels) gets hot in the sunlight faster than soil, concrete, bricks, etc., so something had to be wrong in your calculations.
Anyway - it is not that easy to model the heatflow with reasonable accuracy. Even if you integrate Planck's law over whole spectrum...
In most cases the experimental approach is used to determine the values used for practical calculations.
