Calculating I = 2nd Moment Of Area (m4) on C section beam
The discussion focuses on calculating the second moment of area (I) for a C-section beam, particularly about non-symmetrical axes. Participants seek guidance on correcting their calculations and understanding the radius of curvature and maximum stress points under load. Key points include the application of the parallel axis theorem and the distinction between radius of gyration and radius of curvature. The conversation also touches on the relationship between inertia, beam dimensions, and load capacity, emphasizing the need for accurate calculations to determine the minimum size of the C-section under various loads. Overall, the thread serves as a collaborative effort to clarify complex structural engineering concepts.
hmk999
https://skydrive.live.com/redir?resid=22F7BBABD7DEE83B!136&authkey=!AP6uQQ9mR04UuAE
Can anyone please help.
I have calculated the area and Neutral Axis about xx and yy of a C section beam which I know is correct (see above link)
I'm have difficultly calculating the 2nd moment of area about xx & yy because the shape is not symmetrical, I have shown my workings but I know its incorrect. Can anyone help.
I am also unsure how to calculate the Radius of curvature about the neutral axis xx & yy
I would appreciate if you could show me step by step to give me a better understanding.
Thanks
hmk999
Your calculation shows the inertia calculated about the horizontal axis.
There appears to be an extra 0 in your final result.
I did not find a similar inertia calculation about the vertical axis.
I am attaching a tabular form version of your inertia calculation.
This form is more compact, easier to check, and able to handle calculations
involving a large number of parts. It is superior to what most textbooks
show for similar calculations. It is also readily adapted to calculation
with a spreadsheet like Excel.
Thank you for your reply, much appreciated.
I was unsure where to start about the vertical axis.
Could you please attach with the vertical answer as well?
I can then try and break it down to understand for future moment of inertia calculations I have to do.
Thanks again
hmk999
It's a similar calculation to the one for the horizontal axis.
I recommend you use the left side of the channel as the reference.
Post your work and I'll be glad to check it.
Hi, can you explain how you calculated the I values?
Part A = 12500
Part B = 20747573
Part C = 8333
Cant see how there calculated.
Secondly, in part of the calculation INA = ΣI0 + ΣA*y2 - A*y2
INA = 186116027 - 109396827 INA = 76719200 mm4
I get 5420*142.07squared = 109396656 not 109396827.
Cant see what I'm doing wrong.
Can you please explain
Thanks
hmk999
The Io values are the second moments (inertia) values of each part about its own center of gravity. For a rectangle, Io = (base/12)*(height^3)
In the calculations of Ina, the parallel axis theorem says to subtract the total area A times the square of the distance to the NA. Since the distance to the NA = Mom / Area, then we can rewrite A*d^2 = Mom^2 / A. In this fashion, when dealing with large numbers, some precision is maintained which would be lost by calculating Ad^2.
I understand your explanation
My calculation below shows the inertia calculated about the vertical axis, is this correct?
Item Area x-bar A*X A*Xsq Ixx
part A 1500 75 112500 8437500 2812500
part B 2920 5 14600 73000 24333.3
part C 1000 50 50000 2500000 833333
5420 32.67 177100 11010500 3670166
IYY 3670166+11010500-177100sq/5420
IYY = 8893875mm4
Thanks for your help
I now want to calculate radius of gyration about xx and yy. Is there a similar format and would you be happy to check my calc's once I've done them.
hmk999
The radius of gyration is a simple calculation:
rxx = sqrt (Ixx/A)
ryy = sqrt (Iyy/A)
You already have calculated the values Ixx and Iyy and A required.
Your Iyy calculation looks good.
https://skydrive.live.com/redir?resid=22F7BBABD7DEE83B!138&authkey=!AEL3SAU9F1BCW-Y
See attached link with updated calculations
Hi can you give me a little more advice on this.
Looking at the information I now have for the C section beam. I am trying to understand where the maximum stress points would be under load, I assume it would be the outer faces of the top and bottom flanges of the C section?
If the beam was put under different uniform loads of say 8 tons and 12 tons. What is the formula to work out the max stress for this cross sectional area? I am trying to work out and understand what minimum size the section can be under various loads. Increasing the height and material thickness will change the value of I inertia. But how does this relate to working out max loads you can apply?
I also notice we have Y = distance from the neutral axis which comes into the equation. I assume it’s the distance from the NA to the outer surfaces of the section, also where I think the max stress would occur.
Can you please help me?
The section is mild steel.
Secondly, I understand you would have to calculate across the beam (simply supported beam macauleys method for the max stress and deflection, bending moments etc. Just trying to understand if you can calculate from the cross section only, when under load, what is the minimum size the C section can be?
Hmk999
I have one small comment to make about your inertia calculations.
The gyradius is not the same as the radius of curvature. The gyradius is a property of the cross section alone, while the radius of curvature deals with how a beam would deflect under the action of a bending moment.
There are some calculations you can make about the maximum stress using only the cross section. You must make some assumptions about the axial forces, shearing forces, and any bending or twisting moments applied to the beam.
If you wish to analyze a beam constructed from a C section under various loadings, I would be happy to review any calculations you make.
I would also like to know if you are studying strength of materials, and if this work is related to that study.
https://skydrive.live.com/redir?resid=3B1281F72DB8729B!117&authkey=!AFfQ3vG7MAQH8X8
Hi, if you view the above link, I have created a diagram of half the beam as the beam is symmetrical, to the left of the diagram you will see the centreline and I have also placed a bending moment on the centreline.
Can you please advise if the equation is correct for the bending moment? If not can you advise where I'm going wrong?
I also want to create a equation for the deflection but trying to sort bending moment first.
I've been struggling to get my head round this macauleys method so any help much appreciated.
Not studying anything at the moment, I have an opportunity to learn some FEA at work and just trying to get a head start on some beam theory.
Thanks
Bending moments are usually of interest when they are applied along the length of the beam rather than across the breadth of the cross section.
