Calculating Limits: Understanding Lim 1 - cos(x)/x^2 x->0
  • Thread starter Thread starter Halcyon99
    Limit
The limit of (1 - cos(x))/x^2 as x approaches 0 is calculated to be 1/2 using both series expansion and L'Hôpital's rule. Initial confusion arose regarding the limit's value, with some participants mistakenly calculating it as 0 due to calculator settings. The discussion emphasized the importance of ensuring calculators are set to radians when working with trigonometric functions. Participants shared methods for solving the limit, reinforcing the use of known limits like sin(x)/x approaching 1. The conversation concluded with a reminder about the significance of proper settings in calculations.
Halcyon99
Lim 1 - cos(x)/x^2
x->0
My attempt:
lim [1 - cos (x)/ x][lim 1/x] = (1)(1/0) :cry:
Please help me with some basic examples.
lim [1 - cos (x)/ x]=1?
How ??
While solving limit Problems, you make use of certain solutions
like
\lim_{x\rightarrow 0} \frac{Sin(x)}{x}=1
\lim_{x\rightarrow 0} \frac{e^x-1}{x}=1
eg:\lim_{x\rightarrow 0} \frac{Tan(x)}{x}
=>\lim_{x\rightarrow 0} \frac{\frac{Sin(x)}{cosx}}{x}
==>\lim_{x\rightarrow 0} \frac{Sin(x)}{x} \lim_{x\rightarrow 0} \frac{1}{Cosx}
==>1*1=1
end example==================
In this case,try to convert this into a known limit
HINT:cos2x=1-2sin^2x
use le'hopitals(spelling?) rule
Hmm, I got 1/2. I think you left the x^2 out of the original denominator:
lim x-->0 of ( 1-cos(x) )/x^2
= lim x-->0 ( sin(x) )/2x
= lim x-->0 ( cos(x) )/2 = 1/2
BTW, here's a good page on L'Hopital's Rule:
http://www.math.hmc.edu/calculus/tutorials/lhopital/
PS -- I went back and used a calculator to plug in small numbers for x, and it looks more like the limit of the original function of x goes to zero. I wonder if I did the first differentiation wrong, or the calculator is fooling me. What do other folks get?
Answer
I guess this can be solved in eitherof following 2 ways.:
1. Using formula of cosx=1-(x^2)/2!+(x^4)/4!...
so that
(1-cosx)=x^/2-(x^4)/4!...
=x^2[1-(x^2)/4!...]
so that
Lt x->0 of (1-cosx)/x^2 becomes :
=Lt x->0 of 1/2[1-(x^2)/4!...]
=1/2
2. other method could be usin L'Hospital's rule using differentiation
this too yields answer as 1/2
take care :smile:
Your calculator was probably using degrees instead of radians.
Perfect! Thanks, Muzza. I thought I was losing my mind!
I was going to suggest to Halcyon99 that a good way to check the results you get from L'Hospital's Rule is to just plug some small numbers into the original fractional expression using a calculator. Now I know to add the caveat that the calculator needs to be in Radian mode. I'd spaced the part about when series expansions or other expressions are shown sharing a variable between trig functions and algebraic functions, the trig function arguments are in radians.
Thanks again, -Mike-
