Calculating magnetic field of an infinite strip.
To calculate the magnetic field of an infinite strip carrying a current density J in the z-direction, the discussion emphasizes using Ampere's law, which relates the magnetic field around a closed loop to the current passing through it. The magnetic field is determined to be in the negative x-direction for y > b and positive x-direction for y < -b, following the right-hand rule. Participants express difficulty in selecting an appropriate Amperian loop for integration. The suggestion to integrate is made to find the magnetic field more effectively. The conversation highlights the challenges and methods involved in solving this magnetic field problem.
Berrius
Given an infinite long (in the z-direction), with width 2b in the y-direction and no thickness in the x-direction. There is a current with density J in the z-direction.
Calculate the magnetic field on the y-axis if |y| > b.
Amperes law: ∫B*dS = μ0*I
My first thought was that the strip is build out of infinite wires, so according to the right hand rule the magnetic field would be in the negative x-direction for y > b and the positive x-direction for y < -b. But I see no possibility to choose a suiting ampere path.
Hi Berrius! :smile:
(use ds for length, not dS, or the examiner may think you mean area)
… I see no possibility to choose a suiting ampere path.
so integrate! :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
