Calculating Mechanical Work in an Adiabatic Process of an Ideal Gas
  • Thread starter Thread starter rAz:DD
    Thermodynamics
The mechanical work exchanged by two moles of a monoatomic ideal gas during an adiabatic transformation from T1=400K to T2=277°C is calculated using the formula dW = α * nR(T2 - T1). The ratio of specific heat capacities, γ, is defined as (α + 1) / α, which is crucial for deriving the work done. The final calculated work is 3068 J, accurate to four significant figures. The discussion emphasizes the importance of understanding Poisson's equations and the relationship between temperature and volume in adiabatic processes.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with Poisson's equations
  • Knowledge of the ideal gas law
  • Concept of specific heat capacities for monoatomic gases
  • Study the derivation of Poisson's equations for adiabatic processes
  • Learn about the ideal gas law and its applications
  • Explore the concept of specific heat capacities and their significance
  • Investigate advanced thermodynamic cycles and their efficiencies
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and mechanical work calculations in ideal gases.
rAz:DD
Two moles of an monoatomic ideal gas are experiencing an adiabatic transformation; during this time the temperature modifies from [tex]T1=400K[/tex] to [tex]t2=277^o C[/tex].
What's the value of the mechanical work exchanged by the gas with the exterior?
The mechanical work's formula, Poisson's equations
First i wrote this
[tex]L=(p_1V_1-p_2V_2)/(g-1)[/tex]
Then wrote Poisson's equations, replaced the temperature with the given values, then find out V1 in function of V2 and p1 in function of p2.
Replacing them in the first equation would get me a wrong answer (2.6 = 1)
I haven't done any thermodynamics exercise for 3 years and i quite forgot the stuff.
Sorry for the weird terms i may have used, don't know them exactly in english.
http://en.wikipedia.org/wiki/Adiabatic_process
The section Titled "Derivation of Discrete Formula" has all of the equations you should need to derive a law.
Remember that the ratio of specific heat capacities of a mono-atomic ideal gas is related to the number of degrees of freedom. http://en.wikipedia.org/wiki/Monatomic_gas
You should end up with:
dW = alpha *nR(T2 - T1)
... where gamma = (alpha + 1) / alpha (gamma is the ratio http://en.wikipedia.org/wiki/Heat_capacity_ratio)
This gives the magnitude of dw as: 3068 J to 4 significant figures.
Let me know if this helps.
  • · Replies 22 ·
  • · Replies 60 ·
11K
