Calculating Moment of Inertia Homework: Soccer Ball
The discussion revolves around calculating the moment of inertia (κ) for a soccer ball rolling down a ramp. The initial parameters provided include mass, radius, time, distance, and height. The calculations involve using energy conservation principles, leading to derived equations for velocity and κ. A significant point raised is the discrepancy in the calculated time, which seemed excessively long compared to expectations. Ultimately, the user resolved the issue by correcting the units in their calculations, successfully obtaining the correct κ value.
Shawkify
An object rolls down a ramp starting from rest, demonstrate symbolically the calculation needed to go from time given to a measured κ value here. Pick your favourite object and perform the calculation.
d, m, R, t, h are known
http://puu.sh/luare/10352d0479.png
Soccer Ball:
m = 331.2 kg
R = 10.54 cm
t = 2.25 s
d = 0.2805 m
h = 0.0445 m
Derived from an earlier problem:
a = (g*h)/(d*(1+k))
d = 1/2*a*Δt2
KEtotal = 1/2*m*v2 + 1/2*I*ω2
I = κ*m*R2
U = m*g*h
v = v0 + a*t
Ui = KEf
m*g*h = 1/2*m*v2 + 1/2*I*ω2
m*g*h = 1/2*m*v2 + 1/2*κ*m*R2*(v/R)2
g*h = 1/2*v2 + 1/2*κ*v2
κ = (g*h)/v2 - 1
v = (g*h)/(d*(1+k))*t
Solving a system of equations gives me:
v = (2*d)/t
κ = (g*h*t2 - 2*d2)/(2*d2)
Plugging in values gives me v = 1.65 m/s and k = 30.8. Compared to a chart which gives a value of κ = 2/3 for a thin spherical shell, my κ value is extremely large.
κ = (g*h)/v2 - 1
You lost a factor of 2 there, but it reappeared later.
Shawkify said:
t = 2.25 s
That seems like a very long time, given the set-up. It should be more like 0.6 s.
Shawkify said:
v = (2*d)/t
How do you get that from these numbers? (2*0.2805)/2.25=0.25
Thanks for your help, I've been told the units for this problem were all messed up and have successfully solved the corrected version.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
