Calculating nozzle shape for melting hot glue
The discussion revolves around the mathematical modeling of heat transfer in a nozzle for a hot glue gun, specifically focusing on how to calculate the rate at which hot glue can be extruded through nozzles of varying lengths and shapes. Participants explore concepts related to thermal conductivity, heat transfer, and the geometry of the nozzle.
  • One participant expresses a desire to use Fourier’s law to calculate heat conduction through a truncated cone, seeking to understand how nozzle length affects the melting of the glue stick.
  • Another participant questions the state of the thermal conductivity of the glue and highlights the complexity of the heat transfer problem due to phase changes and varying material properties.
  • A participant suggests that the mass flow rate is primarily determined by the power of the heater, implying that nozzle design may be less critical if sufficient heating power is available.
  • One participant notes that in most hot glue guns, the nozzle itself is not heated, and the melting occurs further back in a cylindrical tube, which may differ from the participant's experience with a heated nozzle.
  • Another participant expresses curiosity about the mathematical calculations for thermal transfer in a truncated cone and how to predict the time required for the glue to reach the target temperature.
  • Some participants share their experiences with different designs of hot glue guns, emphasizing that while the shapes may vary, the fundamental operation remains the same.
Participants do not appear to reach a consensus on the specifics of heat transfer in the nozzle design, with multiple competing views on the role of the nozzle's heating and the complexity of the thermal dynamics involved.
Participants acknowledge the limitations of their assumptions regarding the state of the glue, the heat of fusion, and the complexities introduced by phase changes and material properties during the melting process.
This discussion may be of interest to individuals involved in DIY projects, engineering design, or those seeking to understand thermal dynamics in material processing applications.
DustinSmith
I am building a nozzle for my hot glue gun, and it has made me realize that my math skills have become quite rusty.
My goal is to figure out how fast I can extrude a hot glue stick through nozzle of different lengths. My assumption is that the longer the nozzle is (assuming I keep it at temperature), the more surface area there will be to heat the glue stick. While I could just start experimenting, curiosity has taken hold of me and I would like to know how to find the answer mathematically. After browsing the internet for a while I believe Fourier’s law is what I need to use, but I am having trouble applying the equation.
From what I understand, I need to calculate heat conduction through truncated cone (melted end of hot glue against nozzle), where heat is applied to the curved surface. This will tell me what volume glue I can melt at a given nozzle temperature / length.
Knowns:
Hot glue stick diameter (base of cone): 13 mm
Nozzle diameter (truncated end of cone): 3 mm
Temperature of Nozzle: 190 C
Melting temperature of glue: 70 C
Thermal Conductivity of glue: 0.25 Watt/m - °C
Thanks!
Science news on Phys.org
In which state? Liquid or solid?
What is the heat of fusion?
I think this would be a very difficult heat transfer problem. The change of state, the converging nozzle, the melting range (most thermopolymers don't have a melting point), and how the fluid properties (density, viscosity, conductivity etc) change over that range would all make it a very hard problem.
A textbook on injection molding/ plastic extrusion would probably be a good place to start.
The mass flow rate is ultimately determined by the power of the heater. Pretty much any nozzle will work given enough power.
Thanks for the response -
For the purpose of this problems, let's simply set a target temperature of 70 C. After looking at this problem some more, I realize that I will need to know how much energy the material holds before I know how much the temperature will increase.
How do I calculate the thermal transfer of a truncated cone? Maybe I could start by looking at how much energy is transfer ed into the material and make some predictions about how long it will take for the center of the material to reach the target temperature.
Thanks again
All the hot glue guns I have owned or seen, the nozzle isn't heated . Its just a coned shaped outlet
the heating/melting is done further in, in a cylindrical tube that has a just slightly larger internal diameter than the glue stick
the nozzle just reduces that diameter down to a smaller size to ease in the use of application of the glue
Dave
Dave
I must have a strange one because the glue stick is pushed into the nozzle which has a heat coil where the nozzle threads into the hot glue gun. I am sure it does not do the bulk of the heat transfer, but now I am just curious.
nothing like this huh ?? ...
there's varieties in shape and manufacture but they all work the same
cold glue stick in the back end, hot melt out the nozzle
http://www.bing.com/images/search?q=hot+glue+guns&FORM=HDRSC2if yours is different, maybe a pic of your one so we all know what you are referring tocheers
Dave
Dave
Latter I'll see if I can post a picture of it, but really I am just interested in the math at this point.
More than anything I am curious how to calculate the rate of heat soaking into a material based on it's shape. In the past I encountered a situations where I was unsure how fast heat would soak into another material, and just guessed until it worked. It would be nice for this project, and future projects to be a little more intentional.
  • · Replies 26 ·
