Calculating optical properties of an arbitrary gas?
Calculating the optical properties of a gas based on its composition is complex, particularly for mixtures like 50% gaseous sulfur and 50% mercury at high temperatures and pressures. While basic properties like pressure and density can be derived from fundamental laws, determining the refractive index and light absorption spectra requires empirical data and advanced quantum physics theories. Helium serves as a simpler case for approximate calculations, but beyond hydrogen, accurate predictions become challenging. The refractive index of gases is generally low and varies linearly with pressure, necessitating empirical studies for precise values. Overall, while theoretical approaches exist, empirical data remains essential for practical calculations of gas optical properties.
Artlav
Hello.
Is there a way to calculate properties of a gas, given only it's composition?
I.e. let's say i want to know what would a planet look like with an atmosphere of a mix of 50% gaseous sulphur and 50% gaseous mercury, at 500*C and surface pressure of half that of Earth.
How would i go about calculating that just from basic laws?
I kind of know where to start regarding the pressure, density and so on, but i have no idea how to get the refractive index and light absorption by wavelength, for example.
Is it even possible?
If so, what should i look for?
Science news on Phys.org
These properties (light absorption spectra ) can be experimentally verified, measured, however it is too complicated to compute from pure physical theories. The theories pertaining to light absorption and so on are quantum physics, which don't permit easy computation - anything beyond a helium atoms is to complex to work out,analytically, only approximately. So we are reduced at this level to empirical study in many respects.
Hm, interesting.
Two directions then.
First, how do you compute it for a helium atom, even approximately?
I'm looking for key words.
Second, is there enough empirical data to calculate a refractive index for common gasses at given conditions?
I found data sets online (i.e. http://refractiveindex.info ), but they only show it at or near sea level pressure and temperature.
The Refractive index can be inferred from electromagnetic theory, and density of material. I can tell you that Helium has the record lowest refractive index of all the elements. As for spectral absorption which is more important, that may be calculated with perturbation theory in Quantum Physics. I don't know if we can accurately predict much beyond the spectrum of Hydrogen. We can explain a lot of phenomena. Maybe we can, my Quantum understanding is quite limited.
I can also tell you Gold is gold coloured because of relativity http://en.wikipedia.org/wiki/Relativistic_quantum_chemistry#Color_of_gold_and_caesium
You go look on Physical chemistry charts for the spectral absorption.
Gases in general have very low refractive indices, however the refractive index varies approximately linearly with pressure. (n-1 is proportional to pressure) Furthermore, there are many complications. http://en.wikipedia.org/wiki/Refractive_index
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
