Calculating Output of Solar Cells in KWH
The discussion revolves around calculating the output of solar cells in kilowatt-hours (kWh) for a small solar cell project. Participants explore methods for determining the electrical output based on the specifications of the solar panels and the connected load (bulbs). The conversation includes both theoretical calculations and practical considerations regarding the setup.
  • One participant outlines a method for calculating output in kWh using the formula Kilowatts = (Amperes * Volts)/1000, applying their values to arrive at an output of .000094734 kWh.
  • Another participant questions the initial calculation, emphasizing that the voltage of the bulbs should not be included in the power calculation, suggesting that only the solar panels' voltage should be considered.
  • A third participant warns about potential inaccuracies in calculations if standard SI units are not consistently used, advocating for keeping calculations straightforward by not mixing units prematurely.
  • Concerns are raised regarding the open circuit ratings of the solar panels, indicating that the output voltage may drop under load, which could affect the calculations.
Participants express differing views on the correct approach to calculating the output of the solar cells. There is no consensus on the method to be used, and the discussion remains unresolved regarding the best practices for these calculations.
Participants mention the importance of using standard SI units and the potential discrepancies between open circuit and loaded ratings of solar panels, which may affect the accuracy of output calculations.
assuc
hi,
I am working on a small solar cell project for which i bought two small solar cells panels of 6volt each producing current of 5.263milli ampere in combination.
I want to know that how can i calculate the values of solar cells output in kwh, on the output i have placed two bulbs of 3 volts in series and connected solar cells in parallel so as to increase the current.
Or any other method of calculating values and please recommend a graphical value too.
All answers will be highly appreciated.
I'm relatively new to physics, (17 going to college physics next year), but I believe you have everything you need to understand the output in Kilowatts per hour.
Kilowatts= (Amperes * Volts)/1000
Kw= (.005263 * 18)/1000
Kw= .000094734
^here above i converted the milli amperes into regular amperes then combined the voltages of both the 6 volt solar panels and the two 3 volt bulb. Then to top it off, I divided by 1000 for converting watts into kilowatts. Then for kilowatts to kilowatts per hour, multiply by 1 hr and you still get the same number as an output, or .000094734KwH.
That's for the combined system I assumed you wanted, otherwise you wouldn't have needed the bulbs.
Again, I'm VERY new to just physics in general, but I try to help since there are no replies yet :/ And I just did basic equations...
Kw= .000094734
I really appreciate your answer...!
But the confusion is that you have combined the output voltage of each bulb while taking out the kilowatts... as i am only concerned about the power solar cells are producing not the bulbs, as to best of my knowledge we will multiply the voltage value of solar cells and that will be 6Volts (as both solar panels are in parallel so the voltage remains same in parallel combination).
Do correct me if i am wrong.!
thanks again
just a couple of comments :)
@ physicsofme...
always use the standard SI units when doing formula, do any conversions at the end
so always use W = V * A etc, else you may get into strife with more complex calculations :)
Also, your globe voltages should NOT have been included, that's giving false info.
As assuc said its the power generated by the panels that is being calculated. The globes are not supplying voltage to the system, in your calc they incorrectly are.
@assuc...
The 6V and 5.263 mA is probably the open circuit (no load) ratings. Under load, the output voltage is going to drop a volt or so. check the paper work for the panel and see if it comments on no load and loaded ratings :)
cheers
Dave
  • · Replies 38 ·
