Calculating partial derivatives in different coordinate systems
2 replies · 4K views
oblixps
let f = x2 + 2y2 and [tex]x = rcos(\theta), y = rsin(\theta)[/tex].
i have [tex]\frac{\partial f}{\partial y}[/tex] (while holding x constant) [tex]= 4y[/tex]. and [tex]\frac{\partial f}{\partial y}[/tex] (while holding r constant) [tex]= 2y[/tex].
i found these partial derivatives by expressing f in terms of only x and y, and then in terms of only r and y. But i am sure there are times where it can be very difficult to solve for one variable or to express some function in terms of specific variables.
Is there a way to relate the 2 partial derivatives with respect to y (one holding x constant and one holding r constant) using the chain rule or something?
oblixps said:
let f = x2 + 2y2 and [tex]x = r \cos(\theta), y = r \sin(\theta)[/tex].
This is a very confusing procedure. I would agree with your first result. That's a straight-forward application of the definition of partial derivative. However, for your second result, you seem to be defining the function $f=f(r,y)$. I'm not sure I would consider that to be a very good definition, because $y=y(r,\theta)$, so the variables you are putting forth as "independent" are not actually independent. Typically, you would write $f=f(r,\theta)=r^{2}(1+\sin^{2}(\theta))$, and then compute either $\partial f/ \partial r$ or $\partial f/ \partial \theta$.
Hi oblixps! :)
Apparently you want to calculate the total derivative under the condition that r is constant.
This is typically written as something like:
$({df \over dy})_{r \text{ constant}}$
It can be calculated with repeated application of the multi variable chain rule as follows:
[1] $({df \over dy})_{r \text{ constant}} = ({d \over dy}f(x(r,y),y))_{r \text{ constant}}
= ({\partial f \over dx}({\partial x \over \partial r}{dr \over dy} + {\partial x \over \partial y}{dy \over dy}) + {\partial f \over \partial y}{dy \over dy})_{r \text{ constant}}
= {\partial f \over \partial x}{\partial \over \partial y}x(r,y) + {\partial f \over \partial y}$
To calculate ${\partial \over \partial y}x(r,y)$, we can use that:
$x^2 + y^2 = r^2$
Therefore $2x dx + 2y dy = 2r dr$
Meaning $dx = \frac r x dr - \frac y x dy$
It follows that
[2] ${\partial \over \partial y}x(r,y) = - \frac y x$
Substituting [2] in [1] and using that $f(x,y)=x^2+2y^2$ gives:
$({df \over dy})_{r \text{ constant}}= {\partial f \over \partial x}{\partial \over \partial y}x(r,y) + {\partial f \over \partial y}
= 2x \cdot - \frac y x + 4y = 2y$
As you can see this is the same result you already derived by making the relation explicit in r and y.
